Sold FS: Avionixx AXA440.4
JAZN
Just bought matching amps so I don't need my Avionixx AXA440.4 anymore. I don't have the mounting feet. Condition, I'd say a 8.5/10 to be safe. Definitely a powerful amp, pushed my Adire Extremis to their limits.
Specs:
High Current, 2 ohm stable Amplifier
Number of Channels 4
MAX Power @ 4ohm 2x440 Watts Bridged
RMS Power @ 4ohm,
RMS Power @ Bridged 4 ohm
RMS Power @ 2 ohm,
Power Bandwidth (Rated Power -1dB) 15Hz - 30kHz
Frequency Response (+0/-3dB) 5Hz - 70kHz
"A" Weighted Signal to Niose Ratio >-90dBA
Channel Seperation >60dBA
Damping Factor >200
Variable Input Level 150mV - 6V
Variable Frequency Bass EQ 25Hz - 80Hz
Controlled Electronic Noise Suppression "Cens" Yes
Variable Low Pass Crossover Filter 50Hz - 250Hz 12dB
Variable High Pass Crossover Filter 50Hz - 250Hz 12dB
Double Sided, 1Oz. Copper Clad FR4 board Yes
Overload Protection Yes
Short Circut Protection Yes
DC Off-Set Protection Yes
Thermal Protection Yes
Fuse 2 x 40A
Heat Sink Dimensions - Inches 13 7/8x 9 7/8 x 2 1/4
Heat Sink Dimensions - Millimeters 352 x 251 x 57
Weight 12 Lbs
$120 shipped, paypal preferred (w/ confirmed address).
BUMP
JAZN is good people.
So is this amp. Its more like 9/10 for looks ( ive seen it )
Its also under rated //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Wheres the control for the Bass EQ? You wouldnt happen to be looking at a alpine MRD-M605 amp as a trade would you? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
There's no bass EQ as far as I know, since it's a 4ch. Not currently looking for trades, just need the money for xmas //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
item description says... "Variable Frequency Bass EQ 25Hz - 80Hz"
thats why I asked.
Hmm, I haven't a clue where it is, my apologies. If anyone knows, could ya help me out pretty please //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Just copied/pasted specs from somewhere.
JAZN
JAZN
SoCAL
supa_c
