Sold FS: Autopage RS-860 LCD
got_focus?
Skeet Skeet Skeet
Brand new in box Autopage RS-860. Bought this a while back and never had a chance to wire it up in my car. Rather than let it sit any longer and collect dust, up for sale it goes!
Looking to get $80 shipped out of it.
Will trade for NICE components 6.5" (plus cash on my side), a single 10" SQ oriented sub, or a nice pair of 6x9's (cdt preferred)
Specs/Features
Six-Channel Alarm System with Remote Car Starter and Two Way FM/FM Paging LCD Remote Transmitter
STANDARD COMPONENTS:
· 6 Channel Alarm and Remote Car Starter with 5 on-board relays for parking lights, starter, accessories, ignition 1&2 and one additional relay / socket for starter disable.
· 'On-Board Serial Port for AP DATA LINK Data Bus Integration
· Two-way paging receiver and transmitting remote with 3-color LCD screen using FM frequency bands for transmitting and receiving at 433.9 megahertz. Unit will transmit and receive up to 2000 feet. Unit also includes 24-hour clock with meter minder and temperature indicator and countdown run timer.
· New Molex-plug wiring harness
· Two-way, window mount extended range helical transceiver antenna module.
· One 4-button extended range FM, standard 433.9-megahertz remote transmitter.
· SIS-11 Super Intelligent Sensor with dual stage shock / glass sensitivity.
· Discrete Temperature Sensor that communicates in-car temperature with LCD remote.
· Window-mount Knock Sensor for driver paging.
· Plug-in super bright mini-LED and push-type valet/override switch.
120 dB loud single tone siren.
TWO-WAY LCD REMOTE OPERATION:
· 5-button configuration with selectable Button Lock to prevent accidental mis-use.
· Uses one AAA type 1.5volt alkaline battery with battery life indicator and power save mode
· 3-color LCD screen displays 29 icons and figures that provide for around-the-clock visual confirmation on vehicle and alarm status. Back lighting for nighttime use. Channels 3,4,5,6 indicators on LCD screen
· Optional Two Car Operation with LCD transmitter only
· Transmits on FM band and receives on FM band.
· 24-hour digital clock with count down timer for parking meter reminder. The clock doubles as a temperature indicator for monitoring in-car temperature. Displays in Fahrenheit or Celsius.
· Multiple audible confirmation tones as well as vibrator mode for paging.
LCD Transmitter Range Check Indicator
ALARM FEATURES:
· Six Channels of outputs (3 dedicated to lock/unlock, trunk and remote start / 3 auxiliary outputs)
· Dedicated function buttons on LCD remote and 4-button standard remote transmitter.
· Code learning / Anti-scan receiver with programmable code hopping.
· Back-up memory system
· Selectable Chirp Confirmation (OEM Style lock only chirp confirmation)
· Comfort Feature with OEM systems having key / remote control power window roll-up
· Dedicated remote panic and car locator
· Passive arming by-pass from the remote
·Parking light flash with dual polarity relay on-board
·Plug-in dual stage SIS-11shock sensor with sensor by-pass from the remote
·Starter disable output with relay and socket included
·Dome light illuminated entry output
·Dual polarity (+/-) door lock outputs with optional driver s door priority two step unlock
·Additional positive and negative inputs
·500 mA grounded outputs for starter disable and door lock/unlock
·Programmable momentary, latched or timer on 3 auxiliary channels.
·Programmable manual / passive arming with true last door arming with auto re-arm on
·Programmable Single / Double Pulse Unlock
·Programmable Parking lights (flash or constant)
·Programmable Pathway Illumination (on / off)
·Programmable voltage sense for delayed dome lights (on / off)
·Programmable horn and siren chirp delete
·Programmable ignition control lock and unlock
·Programmable pulse time for lock and unlock (.9 sec. / 3 sec.)
REMOTE CAR STARTER FEATURES:
·5 On-Board Relays:
Ignition 1
Ignition 2
Starter
Accessory
Parking Light
·3rd Ignition (-) output
·Ground when start (-) output
·New Turbo Timer feature
·2nd Accessory (-) output
·Selectable one or two push Safety Start
·Programmable gasoline or diesel with 10, 15, or 20 second Wait-to-Start
·Hood pin switch safety input (pin switch included)
·Selectable RPM / Voltage Start
·RPM / Voltage / Hi-Low level check
·Timer control start option
·Sensor control output during start
·Temporary Stop Feature
·Factory Alarm Disarm and Rearm signal output
·Programmable factory keyless door locking before and after start
·Programmable start status output with shock sensor bypass
·45 second door / dome light bypass after ignition is turned off.
·Programmable Ignition 2 (on / off)
·Programmable 3 hour timer start
·Programmable 1 / 3 hour timer start
·Selectable Run Timer (5/10/20/30 minutes)
·Ignition control by-pass during remote start
·Selectable Gasoline / diesel
·Selectable Diesel warm-up time
·Programmable Ignition control locks bypass (on / off)
got_focus?
Skeet Skeet Skeet
got_focus?
Loveland, CO
got_focus?
