Up for sale is my AudioControl Matrix 6 Channel Line Driver & 6XS Car Audio Equalizer. These units are almost brand new. Cosmetically 8.5/10. There may be a couple of fine scratches and marks around the screw terminals. These units are in pefect working order. I have all the original boxes, accessories, manuals, etc. I recently sold my car and the audio system must go too. I can email more pictures if neccessary. I also have some great great KnuKonceptz Interconnects and a large amount of vintage car audio for sale. Please call Shawn @ 647.298.1753.
I have feedback on Head-Fi.org - Headphone forums and reviews for audiophiles (Screename: sk3383)
sk3383 - Head-Fi.org Community
Ebay Feedback: shawnkhan83
I have feedback on Canadian Car Audio (Screename: Throatrattling)
AudioControl Matrix - $150 USD Shipped
Six channels of input and output
24 dB of signal gain
13 volts peak output 12 dB of signal attenuation
PFM subsonic filter
Output level controls
Balanced differential inputs
Linkable inputs 2 input channels to 6 output channels
Low impedance outputs
Voltage indicator LEDs
AudioControl 6XS - $150 USD Shipped
Description:
AudioControl's 6XS 6-channel crossover uses a steep 24 dB per octave slope to separate your high and low frequencies, along with a built-in line driver that'll beef up the signal from an anemic receiver.
The 6XS crossover features front. rear, and subwoofer inputs, along with four sets of outputs: front high-pass, front low-pass, rear high-pass, and subwoofer. It comes preloaded with crossover modules that will work in a number of system configurations, but you can change the crossover point by buying another AudioControl module, or by modifying the modules installed in your 6XS. A built-in filter cleans up extreme subsonics in your signal so your amps and subs will play louder and cleaner.
Features:
6-channel Linkwitz-Riley electronic crossover
white steel chassis with gold-plated RCA jacks
line driver with adjustable output (up to 9 volts)
top-mounted controls for easy adjustment
6-channel inputs (front, rear, sub)
balanced inputs eliminate noise
PFM subsonic filter (18-100 Hz at 18 dB/octave)
frequency response: 10 to 100,000 Hz
signal-to-noise ratio: 110 dB
maximum output level: 9.5 volts (13v peak)
fuse rating: 2 amps
size: 7-1/4"W x 1-1/4"H x 7-3/4"D
8-channel outputs:
front high-pass: 250 Hz and up
front low-pass: 90-250 Hz
rear high-pass: 250 Hz and up
subwoofer: 30-90 Hz
PFM subsonic filter
Description:
Features:
fuse rating: 2 amps
8-channel outputs:
subwoofer: 30-90 Hz
