I just bought this amplifier from my local dealer, but have decided that I need a bigger four channel due to a change in the set up I'm going with. It's in perfect condition with all original packaging and paper work. Here are the specs:
Features:
Built-in variable 12db per octave crossover
Crossover range 55Hz-5.5Hz
Stereo/Bridged/Mono input model selector switch
Bass boost 0-18dB @ 45Hz
Short circuit, thermal, reverse voltage, over-voltage and DC offset protection
Very high damping factors
Optically isolated MOSFET power supply
Fully regulated power supplies produce full power output with battery voltages as low as 12 volts
Symmetrical, discrete power amplifier circuitry
Engineered to drive highly reactive loads
Built-in variable crossovers, 12dB per octave
12dB/24dB per octave subwoofer crossover
Remote bass boost 0-18dB @ 45Hz
Microprocessor controlled power supply and protection circuits
Designed, engineered and assembled in the USA
Specifications:
Power Output at 4 Ohms Stereo: 4x50 Watts
Power Output at 2 Ohms Stereo: 4x90 Watts
Power Output at 4 Ohms Bridged: 2x180 Watts
THD: Frequency Response: 20Hz-20KHz
Signal to Noise Ratio: 95dB
Signal Separation: >65dB
Transient Dist: Input Sensitivity: 250mV-2.5V
Bass Boost: +18dB @ 45Hz
Crossover (Butterworth): 55Hz-5.5Khz, 12dB Stereo
Max Current Draw: 46 Amps
Damping Factor: >300 @ 1KHz
Dimensions: 13"x8"x3.35"
I bought it for $280 and really just want to make most of my money back. I'm going to let it go for $270 shipped. I have plenty of references available here, on Ebay and other forums as well. Don't hesitate to ask. Thanks!!
Features:
Specifications:
