Used amp for about 6 months. Worked great powering my ascendant audio 10" sub bridged. Birth sheet included shows 118w @ 4ohm.
Features
* High/Low/Full Range Selector Switch
* 50Hz – 5.5kHz Variable 12 dB/Octave Crossover
* 0-18dB @ 45Hz Variable Bass Boost
* Stereo, Bridged, or Summed Mono Input Mode Switch
* Reverse Voltage, Over Voltage, Speaker Short, and Thermal Overload Protection
* Heavy-Duty Construction with Cast Aluminum Heat Sink
* Deluxe, Audiophile Grade RCA Connectors
2-Channel Amp Specifications
* Amplifier Type: 2-channel
* RMS Power @ 4 Ohms: 50W x 2
* THD at 4-Ohm RMS Power: 0.03 %
* Bridged RMS Power @ 4 Ohms: 230W x 1
* Speaker Level Inputs: no
* Preamp Outputs: no
* Built-In Crossovers: HP/LP
* Bass Boost: 0-18 dB
* Frequency Response: 20-20,000 Hz
* Signal to Noise Ratio: >100 dB
* Fuse Rating: 25 amps
$100 shipped
Features
$100 shipped
