FS: Apline PDX-M12 Mono amplifier
ARFJUKE
Item(s) for Sale: Alpine PDX-M12 amplifier
Item(s) Description/Condition: 9/10 functional and 7/10 cosmetic. 100% functional with no problems. Birth certificate showing 1368 watts included. Customized trim ring with Blue carbon fiber. Also, Apline dealer customized the bottom with clear plexi-glass. This is a unique version. Connectors for power and speaker wire included.
CEA-2006 power Ratings
CEA-2006 power Rating: (4/2 I? @14.4V Ƈ%THD+N), S/N 92dBA, ref:1W into 4 I?) 1200W x 1
RMS power Ratings
Per channel into 4 Ohms: (@14.4V Ƈ%THD+N) 1200W x 1
Per channel into 2 Ohms: (@14.4V Ƈ%THD+N) 1200W x 1
Sound Tuning
Crossover Frequency (LPF): Variable, 50Hz - 400Hz (-24dB / oct), (Variable, L.P.F Only 1/2 ch)
Subsonic Filter: OFF / 15Hz / 30Hz
Dimensions
Heat Sink (WxHxD) mm: 257mm x 192mm x 50.8mm
Heat Sink (WxHxD) in: 10-1/8'' x 7-9/16'' x 2''
General
Power Requirements: 14.4V DC (11V to 16V)
Input Sensitivity (RCA Input): Select Vol, 0.1V to 1.0V or 1.0V to 8.0V (For Rated Power)
Cable size: 4 AWG (BATT and GND), 12 AWG (Remote), Up to 8 AWG (Speaker)
Frequency Response (+0, -3dB: 1W into 4 Ohms) for CH-1/2/3/4: 5 Hz - 400 kHz / 0dB ~ -3dB (Reference: 1 W into 4 ohms)
Frequency Response (+0, -3dB: 1W into 4 Ohms) for Subwoofer: 4 or 1 I?
Frequency Response (+0, -1dB: 1W into 4 Ohms) for CH-1/2/3/4: CEA 2006 S/N Ratio (IHF A Weighted, Reference: 1W into 4I?) 92 dBA
FEATURES
Install
Connectors: Quick Disonnect Terminals (Power Terminal and speaker Terminals)
Terminal Layout: One-Sided
Mounting Design: Easy Stacking and Clean-look intallation
General
Amplifier Type: Class-D (Digital)
Channel Design: 1 Channel (Mono)
Thermal Protection:
Low-battery Protection:
Power Supply: Resonant Mode power Supply
Power Supply Design: DC-DC PWM power Supply
Board Circuitry: STAR Ciruit
Current Protection: Auto Over-Current Protection
Power Indicator: Top Mounted Blue LED Power/Status Indicator
RCA Output: Non-Fading Pre-Amp Output
Crossover: Adjustable Low-Pass
Pre-Amp Stage: Discrete
Final Outputs: MOSFET
Board Design: 6-Layer Glass Epoxy PC Board
Gain Control: Adjustable
Price: $300
Shipping and Miscellaneous Item Information: Buyer to pay shipping and insurance
ARFJUKE
ARFJUKE
fairfield, ct
The Silverman
