I have a NIB Alto Mobile USC Pro 3-way processor with rare optional controller up for grades. This the second gen unit with upgrade power supplies.
Asking 370 shipped in the US for both.
[/img]
[/img]
Here are specs:
Channel Layout:…………………………2 inputs / 6 outputs (phono type)
Max. input/output level:………………..Inputs 2V rms / Outputs 2.2V rms (0dB).
Conversion:……………………………...24 bits A-D and D-A
Freq. Response:…………………………20Hz - 20KHz (+/- 1dB)
S/N Ratio:………………………………..>95dBA
THD+N:………………………………….0.05% (20Hz - 20KHz)
Channel Separation:……………………>100dB, 20Hz - 20KHz
Input/Output Gain range:……………..-30 to +6 dB (0.5 dB steps)
Crossover Filters:……………………….High-Pass & Low-Pass (Bessel, Butterworth or Linkwitz-Riley), Filter slopes: selectable 6, 12, 18, 24, 48dB per octave
EQ Filters (Input/Output channels):…Gain: +/- 15dB, 0.5dB step
Frequency: 15.6Hz to 16KHz
Bandwidth (Q): 0.05 to 3 octaves, 0.05 oct. step
Channel Delay (Time Alignment):……0 - 291 ms (outputs), 0.021ms step
Dynamic Level Control:……………….Variable Threshold & Ratio, per output channel
On-board Preset Memory:…………….1 factory / 64 user (non-volatile)
PC Interface:……………………………9-pin RS232. Requires PC running Windows 98/ME/XP
Other Interfaces:…………………………25-pin D-SUB connector for optional Programmer
Operating Voltage:………………………11 - 16V DC (negative ground)
Dimensions:……………………………..228 x 175 x 42mm (including mounting brackets)
Weight:……………………………………1.3kg
To me the features are second to none. Here is quick, well not so quick run down of the features:
Edit Mode (Password Protection)
UCS PRO incorporates a password system and your installer may have set a password to ensure that vital settings are
not altered. In this case you will NOT be able to alter all of the parameters via the PC Editor.
In the PC Editor, select FILE > OPTIONS and then the LOCK tab. This will present you with a menu:
Full Edit: This is the DEFAULT mode. No password is set at the factory. From here you can lock the unit by clicking within
the empty Partial Lock or Total Lock buttons. A text box will open, allowing you to enter a password of your own choice.
Click OK. It is important that you remember this password.
Partial Lock: In this mode, only the INPUT parameters may be edited. This is useful since it allows critical settings such
as the crossover points to be locked, while still allowing the user access to some overall EQ adjustment.
To enable Partial Lock, a new password must be entered as above. To disable the lock, click within the empty Full Edit
button. A text box will open. Type the password that was used to set lock mode. Press OK.
Total Lock: No editing is possible in this mode. To enable Total Lock, a new password must be entered as above.
To disable the lock, follow the same instructions for disabling Partial Lock.
Parameter Menus & System Set-up
Introduction to the PC EDITOR
Click on one of the icons on the welcome screen (the block diagram) of the PC Editor. A window will appear showing one
of several 'pages' where you can set the parameters using virtual knobs and sliders or by typing the values. Here is a
brief overview of the various functions that make up the UCS PRO PC Editor. Each is explained in more detail in the next
section.
This page presents 8 virtual slide controls, similar to what you would see on a professional sound mixing desk. From here
you can adjust the input/output LEVELS and output channel MUTE and PHASE.
GLOBAL:
Within the PC Editor's tabbed menu view, you will see a tab labelled "Global" on the far right. This window shows the response curves of all channel outputs and provides a convenient overview of your settings.
NOISE GATE:
You can set the UCS PRO to cut the signal if it falls below a certain level. Most often used to cut the background noise between music tracks.
MASTER DELAY:
Allows a delay to be applied to the signal fed from one or both of the Input Channels.4
CROSSOVER (XOVER):
The UCS PRO is equipped with independent HIGH-PASS and LOW-PASS filters on each of the 6 output channels. For each filter there are 10 different filter type/slope options.
CHANNEL DELAY:
Allows a delay to be applied in order to "time align" each individual output channel. Includes a graphical interface of 6 virtual speakers.
PARAMETRIC EQUALIZATION (EQ):
Each of the channels (both inputs and outputs) has a fully variable 5-band parametric equalizer.
DYNAMIC GAIN CONTROL (CMP/LIM):
Each Output channel has its own independent COMPRESSOR/LIMITER. Careful setting of the parameters will help to
maintain a more consistent and pleasurable listening level and extend the performance of your speakers.
5-band full parametric equalization is provided on each of the Input and Output channels. The Center Frequency, Gain and Bandwidth are all variable. In addition, the UCS PRO allows you to select from a list of different EQ contours.
Freq: The center frequency of each band can be set between approximately 16Hz and 16,000Hz.
Gain: The level at the chosen center frequency can be increased or reduced by 15dB.
Band: This dictates how the frequencies next to the center frequency will be affected during Gain boost or cut. With a
narrow bandwidth (minimum 0.05 octave), frequencies other than the center frequency and its immediate neighbours will
be largely unaltered. With a broad bandwidth (maximum 3 octaves), gain changes will be spread more widely. The effect
can be seen on the PC Editor's real-time graph.
Type: This section allows several types of EQ contour to be applied. Depending on the EQ Type selected, certain parameters
(Gain, Bandwidth) are automatically set (they become greyed out).
Peaking - This default setting is the traditional parametric mode, allowing gain cut or boost at and around the chosen
center frequency.
LowSh6 - This creates a shelved response with a 6dB/octave slope, with the frequency shift occurring towards the lower
end of the frequency scale. Bandwidth adjustment is disabled in this mode.
LowSh12 - A shelved response as above but with a 12dB/octave slope.
HiSh6 - This creates a shelved response with a 6dB/octave slope, with the frequency shift occurring towards the higher
HiSh12 - A shelved response as above but with a 12dB/octave slope.
Here are specs:
section.
GLOBAL:
NOISE GATE:
MASTER DELAY:
CROSSOVER (XOVER):
CHANNEL DELAY:
center frequency.
