Sold FS: Alpine 4-channel, Alpine 10" Type E Sub, 10" MMATS Sub, Matrix 600, 12" Logic Sub
ReDemoN
I have a few things for sale.
All prices include shipping and all the other stuff.
1. Alpine V-Power MRP-F450
Unit is used, but works great
Im moving to a 5-channel so this has to go.
Specs:
RMS Power: 140W x 4 (at 2 ohms)
Brigded Power: 350W x 2 (at 4 ohms)
4/3/2 Channel Operation
High Temperature Protection
Overcurrent Protection
Subsonic Filter
Bass EQ Circuit
Adjustable Crossover (HP/LP)
MOSFET Power Supply
DC-DC PWM Power Supply
Discrete Pre-Amp Stage
STAR Circuitry
Auto Over-Current Protection
Top Mounted Blue LED Power/Status Indicator
Input Channel Selector
Gold Plated RCA Input Connectors
Continuously Adjustable Gain Control
4-Layer Glass Epoxy PC Board
CEA-2006 Power Rating (40hm@14.4V = 1%THD+N), S/N 80dBA (Ref. 1W into 4Ohm): 70W x 4
RMS Power (at 14.4V THD+N, 20Hz-20kHz):
Per channel into 4 ohms: 70W x 4 (0.08% THD)
Per channel into 2 ohms: 140W x 4
Bridged 4 ohms: 350W x 2 (0.3% THD)
Bass Engine Sound Tuning:
Crossover Frequency : 50Hz - 400Hz HP/LP/Off(-12dB/oct)
Subsonic Filter (Fixed): 15Hz
Bass EQ Frequency (Fixed): 50Hz +12dB (Ch3/4) On/Off
Frequency Response: 10Hz - 50kHz (+0,-1dB)
Signal to Noise (S/N): 100dBA (Reference to Rated Power)
Input Sensitivity (For Rated Power): 0.2V to 4.0V (1.0 at Center Detent)
Input Impedance: 10k Ohm
Speaker Impedance: 4 or 2 ohm Bridged
Power Requirements: 14.4V DC (11V to 16V)
Fuse Type: 30A x 2
Dimensions (W x H x D): 13" x 2-23/64" x 9-31/64"
150 Shipped OBO
2. Used Alpine 10" Type E Sub
Will include a box, not sure if its made for the woofer but its sounds good.
Single 4 ohm
Specs:
Dimensions
• Added Volume: 0.056 cu. ft. (Reverse Mount)
• Displacement: 0.061 cu. ft (Front Mount)
• Mounting Diameter: 227 mm (8.9'')
• Mounting Depth: 145 mm (5.7'')
Power Handling
• Peak Power Handling: 750 Watts
• RMS Power Handling: 250 Watts
65 Shipped OBO
3. Used MMATS 10" Sub
Will include a box, I know this box was not made for this sub, its just a prefab box.
This is an older model Mmats sub.
Its not the Procast model.
Just the Pro series.
Its dual 4-ohm.
RMS: 300w
Peak: Not sure Cant find any info on it
85 Shipped OBO
4. Used Matrxx Audio 2-channel amp
The model number is MXP-600S
I have run this amp at 1-ohm at one time.
Handles it easily.
Unique design provides high-density circuit layout and superior vibration resistance.
Each part is tested for accuracy and tolerance during assembly.
Power: 90Wrms x 2 @ 2 ohms, 150Wrms x 2 @ 2 ohms, 300Wrms x 1 @ 4 ohms (mono)
Peak power: 600W x 1 @ 4 ohms mono
Frequency Response: (-3dB) 10 Hz to 25kHz
Signal to Noise Ratio: 105 dB A weighted
Distortion at full rated output: 0.1% THD+N
Damping Factor: >125
Input Sensitivity: 150 mV to 4 Vrms
Idle Current: 1 amp
Dimensions LxWxH : 9"x 9 ¼" x 2 1/8"
125 Shipped
5. Used 12" Logic Sub
Model number MDX12
Says 1500w max
It works
It is a single 4-ohm
25 Shipped
6. 2 7-inch Nesa brand tv's
These are both used but are in great shape.
No scraps on anything
Come with a remote and the a/v box to hook them up.
Nice picture
90 Each Shipped
If you would like some more of different pictures just let me know.
Email Address for contact: tcrazye@yahoo.com
Bump.
Its been a month and no sales //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Sucks but oh well.
Good seller here guys, bought some dynamat off him, exactly as he said it was and all for a good price.
Buy his stuff //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
ReDemoN
ReDemoN
Tifton, GA
plyer3
