Sold **FS: Adassa Warlord CHEAP! (5k RMS)**
528hz
Everything'sMiscellaneous
I've had this amp for a while and really have no use for it. I'm sure someone could use this high powered bastard. I originally bought it from Snoopdan on here.
Zenon based board and pretty much just like the Cactus, RD, Atomic 5k amps. It is a little beat up on the casing, but nothing too major.
Here are the specs:
1 x 1600W @ 4 ohm
1 x 2700W @ 2 ohm
1 x 3400W @ 1 ohm (12V)
1 x 5000W @ 1 ohm (14V)
1 x 5900W @ 1 ohm (16V)
1 x 7500W @ 1 ohm (18V)
S/N Ratio: >100dB
Freq. Response: 10Hz 350Hz (±1dB)
THD @ 4 ohm:
Damping Factor: >350 (1 ohm)
Efficiency @ 4 ohm: 86%
Fuse: External 2 x 250A
Dimensions: 24.4" x 10.6" x 2.6"
$592.25 SHIPPED!!!!
I might try to pick this up from you soon.
Definitely should, man. We hooked it up to two '05 15" XXXs SEALED, firing into the cabin of a Cavalier and God did it sound so good. Not that the amp makes the sound, but this is the only time I have got to hear it play.
Just thought I would throw that out there.
wish I had the cash for this. glws
Thanks, buddy. You need something like this //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
528hz
528hz
In the Space between Space in NM
528hz
