FS 8" TruBass Ultra D4
ace_800
Used in my 66 GTO for about 1.5 years. I only drove it every other week and before I pulled to motor for a rebuild. So over all maybe 10hrs of play time. Only ran them off the OS Xtant 3150 and the current Orion HCCA 150 in a TLine enclosure I had designed by someone here. So no more than 200rms or so.
Specs:
Ultra 8's are rated for 250rms and good up to 500-750w daily (if setup correctly of course)
Specs are as followed Re = 3.4298 ohms
Fs = 37.3410 Hz
Zmax = 46.4751 ohms
Qes = 0.3413 Qms = 4.2834
Qts = 0.3161
Le = 2.2975 mH (at 1 kHz)
Diam = 155.0000 mm ( 6.1024 in )
Sd =18869.1914 mm^2( 29.2473 in^2)
Vas = 10.5085 L ( 0.3711 ft^3)
BL = 14.3582 N/A
Mms = 87.4380 g
Cms = 207.7628 uM/N
Kms = 4813.1816 N/M
Rms = 4.7893 R mechanical Efficiency = 0.1506 %
Sensitivity= 83.7971 dB @1W/1m
NOW 75 shipped 3 day or overnight depending on the zip.
Included
Hey! I need a single 8"!
I was looking at a JL 8w3, but your ad caught my attention. Will this work in an sealed enclosure that is between .3-.4 cu? That's the space I have to work with, as it's a wagon.
Thx,
Joe
Thx,
Joe
ace_800
ace_800
Okinawa, Japan
ace_800
