FS: 2x Xeon X5550 i7 2x 2.66 GHz 3 10k 300GB HDS Loaded.
bossman032
I have a like new workstation for sale. The specs are as follows.
I want $3600. I used it for about 1 week. Do your math. I don't think you will find a better deal. If your serious give me a holla.
You can pickup if your local I got vouches here. Also can make an ebay auction, if need be. Just let me know needs to be sold. //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
http://www.pcmall.com/pcmall/shop/detail.asp?dpno=7786896
The new ThinkStation D20 series from Lenovo includes feature improvements in security, system recovery, and location management. These new models offer a blend of essential features and technology, including:
� Microsoft Windows Vista Business 64 preload (select models)
� Microsoft Windows XP Professional 32 preload (select models)
� Enhanced ECC DDR3 SDRAM system memory standard
� Integrated dual Gigabit Ethernet
� High-performance Intel processor technology with dual processor support
� High-performance video graphics adapters
� Numerous data protection tools
Easy to use and manage
� Systems include a fully integrated recovery environment that works when your operating system is not working
� Innovative mechanical design for easy upgrades and service support
� ThinkVantage Rescue and Recovery software: One-button recovery and restore solution that includes a set of self-recovery tools to help users diagnose, get help, and recover from system crashes quickly, even if the primary operating system will not boot
� ThinkVantage Productivity Center: Guides you to a host of information and tools to help you set up, understand, maintain, and enhance your computer
� System Migration Assistant: Enables system administrators and individual users to migrate a work environment (operating system preferences, files and folders, customized application settings, and user accounts) from one computer to another
� System Update: Software program that helps you keep the software on your system current by downloading and installing software packages (applications, device drivers, BIOS flashes, and other updates)
� Easy-to-service chassis design helps maximizes uptime Productivity Center program
� Easy-to-access high-speed USB 2.0 ports
Optimized for connectivity
Service and support
Worldwide service and support
General
Type Workstation
Product Form Factor Tower
Built-in Devices Speaker
Embedded Security Trusted Platform Module (TPM 1.2) Security Chip
Width 8.3 in
Depth 23.7 in
Height 17.1 in
Weight 59.7 lbs
Color Raven black
Localization English
Processor
Type Intel Xeon X5550 / 2.66 GHz
Multi-Core Technology Quad-Core
64-bit Computing Yes
Installed Qty 2
Max Supported Qty 2
Processor Main Features Intel QuickPath Interconnect
Cache Memory
Type L2 cache
Installed Size 16MB
Cache Per Processor 8MB
Mainboard
Chipset Type Intel 5520
Data Bus Speed 1333 MHz
RAM
Installed Size 4 GB / 24 GB (max)
Technology DDR3 SDRAM - ECC
Memory Speed 1333 MHz
Memory Specification Compliance PC3-10600
Form Factor DIMM 240-pin
Features Unbuffered
Configuration Features 4 x 1 GB
Storage Controller
Type 1 x Serial Attached SCSI - integrated
Controller Interface Type Serial Attached SCSI
Channel Qty 5
RAID Level RAID 0, RAID 1, RAID 5, RAID 10
Storage Controller (2nd)
Type 1 x Serial ATA - integrated
Controller Interface Type Serial ATA-300
Storage
Hard Drive 3 x 300 GB - standard - Serial ATA-300 - 10000 rpm - RAID 5 - factory configured
Optical Storage
Type DVD-Writer - Serial ATA
Card Reader
Type 20 in 1 card reader
Monitor
Monitor Type None.
Graphics Controller
Type PCI Express 2.0 x16 - plug-in card
Graphics Processor / Vendor NVIDIA Quadro FX 1800
Video Memory 768MB
Digital Video Standard Digital Visual Interface (DVI), DisplayPort
Audio Output
Type Sound card - integrated
Compliant Standards High Definition Audio
Input Device
Type Mouse, keyboard
Keyboard
Keyboard Name Preferred Pro USB
Interface USB
Mouse
Technology Optical
Interface USB
Features Scroll
Networking
Networking Network adapter - integrated
Ethernet Controller(s) Broadcom BCM5754, Broadcom BCM5755
Data Link Protocol Ethernet, Fast Ethernet, Gigabit Ethernet
Expansion / Connectivity
Expansion Bays Total (Free) 3 ( 2 ) x front accessible - 5.25" x 1/2H � 1 ( 0 ) x front accessible - 3.5" x 1/3H � 5 ( 2 ) x internal - 3.5" x 1/3H
Expansion Slots Total (Free) 12 ( 8 ) x memory - DIMM 240-pin � 2 ( 0 ) x processor - LGA1366 Socket � 1 ( 1 ) x PCI Express x16/x4 - full-length, full-height � 2 ( 1 ) x PCI Express 2.0 x16 - full-length, full-height � 1 ( 1 ) x PCI Express 2.0 x1 - half-length, full-height � 2 ( 2 ) x PCI - full-length, full-height
Interfaces 10 x Hi-Speed USB - 4 pin USB Type A ( 2 in front ) � 2 x microphone - input - mini-phone 3.5 mm ( 1 in front ) � 1 x headphones - output - mini-phone stereo 3.5 mm ( 1 in front ) � 2 x IEEE 1394 (FireWire) - 6 pin FireWire ( 1 front, 1 rear ) � 1 x keyboard - generic - 6 pin mini-DIN (PS/2 style) � 1 x mouse - generic - 6 pin mini-DIN (PS/2 style) � 2 x network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45 � 1 x display / video - DVI-Analog/Digital (dual link) - 29 pin combined DVI � 1 x audio - line-out (center/subwoofer) � 1 x audio - line-out (rear) � 1 x audio - line-out � 1 x audio - line-in � 1 x audio - SPDIF input - RCA � 1 x audio - SPDIF output - RCA � 1 x audio � 1 x serial - RS-232 - 9 pin D-Sub (DB-9) � 1 x storage - eSATA � 2 x audio / video - DisplayPort - 20 pin DisplayPort
Miscellaneous
Features Security lock slot (cable lock sold separately), administrator password, hard drive password, power-on password, boot without keyboard or mouse, hard drive I/O control, serial port I/O control, USB port control, boot sequence control, unattended start mode
Compliant Standards CE, UL, TUV GS, VCCI, C-Tick, GOST, BSMI CNS 13438 Class B, cUL, NOM, SABS, SASO, CB, FCC Part 15 B, IRAM, RoHS, 80 PLUS, ACA, JEITA
Power
Device Type Power supply
Voltage Required AC 120/230 V ( 50/60 Hz )
Power Provided 1060 Watt
Operating System / Software
OS Provided Microsoft Windows Vista Business 64-bit Edition
Software Norton Internet Security (90 days subscription), ThinkVantage Rescue and Recovery, ThinkVantage Client Security, ThinkVantage Productivity Center, Corel WinDVD
Manufacturer Warranty
Service & Support 3 years warranty
Service & Support Details Limited warranty - parts and labor - 3 years - on-site - response time: next business day
Environmental Parameters
Min Operating Temperature 50 �F
Max Operating Temperature 89.6 �F
Humidity Range Operating 10 - 80%
bossman032
bossman032
killa cali
bossman032
