Two RE RE Series 10" Subwoofers: $65 each shipped, or $120 for the pair. DVC 4 ohm. All the moving parts are in perfect shape, but the mounting ring has some paint missing and a bit of leftover glue from a previous installation. They work flawlessly, I gave them around 150w each in a small sealed enclosure for a month or two until my truck died. Specs can be had here: http://www.reaudio.com/re_specs.html
Two MTX Terminator series 8" subwoofers: SOLD!. DVC 4 ohm. I bought a set of six new and only have two left. These two have been tested and found to work but haven't been used, I ran two of the others in a sealed enclosure and they handled 100w each with ease. They don't hit lows very well, but the midbass was impressive; these would probably work well as a dedicated midbass or low-end in a three way comp set.
Last but not least is a discontinued Vifa PL Series 7" midbass driver, model number PL18WO17-04. SOLD! SVC 4 ohm, 100w RMS, hardly used. I had two but the other's dustcap was smashed in and the cone was slightly creased, I can't find it now. Specifications taken from Parts Express:
*Power handling: 100 watts RMS/140 watts max *VCdia: 1-1/2" *L1: .61 mH *Znom: 4 ohms *Re: 3.0 ohms *Frequency range: 40-4,000 Hz *Fs: 38 Hz *SPL: 89dB 2.83V/1m *Vas: .69 cu. ft. *Qms: 2.60 *Qes: .35 *Qts: .31 *Xmax: 4.5 mm *Dimensions: Overall Diameter: 7-1/8", Cutout Diameter: 5-3/4", Mounting Depth: 3-1/8".
Pics shall follow:
Pics shall follow:
