Im sellin cuz i'm a little short on cash and dont need this much woofer..I had two of these on a Zx2500.1 and they pound hard. They retail for 900 on woofersetc, but i will let them go for 350+ship and pp fees each, or 650 for the pair (plus shipping)
My only trades would be:
either two 12" or 10" q's
A highend head unit, dvd unit, or sq unit.
Here is the spec sheet:
MX SERIES
Product Dimension 12”
Mounting Depth - 10.25”
Mounting Hole Diameter - 11.5”
Overall Diameter - 13”
Bolt Hole Circle - 12.25”
Motor Width - 8.5”
Motor Depth - 2.5”
Basket Depth - 7.75”
Displacement - 0.19 cu. ft.
Weight - 33 lbs.
MX SERIES
T/S Parameters
12”
Electrical Q Value -Qes: 0.503
Mechanical Q Value -Qms: 3.206
Total Speaker Q Value -Qts: 0.434
Free Air Resonance -Fs: 23.165 Hz
Equivalent Compliance -Vas: 59.0 liters
One-Way, Linear Excursion -Xmax: 22 mm
Efficiency -SPL 1W/1m: 83.5 dB SPL
Effective Piston Area -Sd: 480 cm^2
DC Resistance -Re: 1.4 ohm
Nominal Impedance -Znom: Dual 2 ohm
Thermal Power Handling -Pe: 1500 W
Force Factor -Bl: 14.56
Pics:
MX SERIES
Motor Width - 8.5”
Motor Depth - 2.5”
Weight - 33 lbs.
MX SERIES
T/S Parameters
12”
Pics:
