Sold fs: 2 Kenwood 12" shallow mount Subs and Ken Amp
ssackett
Evo Audio
Got 2 like new 12" Kenwood Excelon KFC-XW1200F SVC4 shallow mount subs and a Kenwood 8104d mono block amp. Also have custom made sealed box that fits under the rear seats of a 2008 Quad Cab Chevy/GMC truck. Only local pick up for the enclosure. PM me for price.
$125 shipped for each sub plus pp fee
$115 shipped for the amp plus pp fee
Amp Specs:
Mono subwoofer amplifier
300W x 1 at 4ohms (20-200Hz 0.5%THD)
500W x 1 at 2ohms (100Hz 0.8% THD)
CEA-2006 compliant
Bass Boost f=40Hz Gain 0 - 18dB
Class D Amplifier Circuit
Aluminum Die Cast Heat Sink
Power MOS-FET Switching Power Supply
Speaker Level Input and outputs
Signal Sensing Turn-On
2ohm Load Capability
Line Output Terminals (RCA) for Extension
Blue Illumination
Gold Plated Power & Speaker Terminal
Built-in Variable Low-pass Filter 50-200Hz (24dB/oct)
Built-in Infrasonic Filter 15/25Hz (18dB/oct)
Fuse rating: 40A x 1
8-gauge power and ground leads recommended - wiring and hardware not included with amplifier
11-1/16"W x 2-3/8"H x 9-7/8"D
** Pics uploading now
how did you like those subs? i have been considering a pair
They sounded nice for what they are. If space is not a problem i would never run these but if you trying to fit some gear in a tight spot then they would be a nice pair of subs.
You need to first check your ground, your positive lead, and the 12V turnon from your head unit. If that is all checked then I'm guessing your amp turns off when you really crank the volume, then turns back on when you lower it? If that's the case, then you have your subwoofers wired for too low of an impedance for that amp. Keep in mind, if your amp is 2 ohms stable in stereo, its only 4 ohms stable bridged //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Best of luck.
yup as this guy says
ssackett
Evo Audio
ssackett
CA
ssackett
