I bought some spare diyma's for backups and to use at home but I now I won't end up using these. They are in excellent condition and have sat in the box most of they're lives.
Recommended enclosure is 1cft sealed box .
Single 4 ohm voice coil
QTS: .354
FS: 25hz
VAS: 41.7 L
RE: 3.6 Ohm
BL: 22
SPL: 84.3 dbwm
Le: 1.3mh
Xmax: 23mm 1 way (71% bl, 25% cms)
Xmech: 64mm peak to peak
Weight: 37 lbs
Cutout diameter: 28cm
Mounting depth: 16cm
Driver volume: .15 cft
QTS: .354
FS: 25hz
VAS: 41.7 L
RE: 3.6 Ohm
BL: 22
SPL: 84.3 dbwm
Le: 1.3mh
Weight: 37 lbs
