FS: 2-channel home amps; Sonance 260
Fast1one
I actually have three of these that I was going to use for an active setup but I have changed my plans and will be selling two. The second one is still on it's way. The first is in good condition with minimal scratches on the top edge and the top plate. Powers up fine and is in good working order. The specs are the same as the MKII version; I can email you the PDF if you are interested.
I am asking $90+ shipping each. I will ship UPS and will only ship to the US. Thanks!
Whoops! I thought I could attach the PDF here but it was too big.
SPECIFICATIONS
Output Power, Stereo mode, RMS: 60 Watts per channel @ 8Ω
100 Watts per channel @ 4Ω
Dynamic Power at Clipping: 85 Watts per channel @ 8Ω
125 Watts per channel @ 4Ω
Total Harmonic Distortion: 0.05% 20Hz-20kHz @ 8Ω
0.09% 20Hz-20kHz @ 4Ω
I.M. Distortion (SMPTE 4:1) @ 8Ω: 0.008% @ 1 watt
0.01% @ 60 watts
Signal to Noise Ratio: -100dB below rated output (A-weighted)
Input Sensitivity: 0.625 volts for rated output
Input Impedance: 47k Ω,Min.
Power Requirement: 120 VAC, 50/60 Hz
Power Consumption: 500 watts (625VA)
Heat Output: 750 BTU/HR
Dimensions (WxHxD): 16 3/4" x 3 7/8" x 12 1/2" (425mm x 98mm x 318mm)
RMF 19" x 3 1/2" x 12 1/2" (483mm x 89mm x 318mm)
Special Features: All discrete output devices, no "brick" modules
Toroidal transformer, low hum radiation
Auto Turn-on, input signal detection, can be defeated
In/out RCA jacks, allows multi-linking of amplifiers
Status indicators,AC power and active conditions
30,000uF of power supply capacitor storage
Short circuit protection,with visible indication
IEC Power Connector Chassis ground lift switch for rack mounting.
bridgeable?
Yes and no. They are not configured to be bridged in stock form but you can either purchase or make a bridging module to do it. Not sure exactly where you would buy something like that. That is what a Sonance representative told me. Essentially you need a way to invert one of the channels. Might be as simple as setting the gains exactly the same and flipping the polarity of one of the channels and bridging them together.
bridgeable?
LOL, u kill me. Most home equipment cannot be bridged. Just choices between 16-4ohm loads. If you want to bridge it, just run a DVC sub //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif there, you have your bridge mode //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Or if you have fronts that are bi-ampable, buy two of the 260's and run each channel bi-amped from one //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif That's what I would do with my MV80t's //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Still for sale! Not sure what I am going to do in regards to my next setup. But I am willing to sell 1,2 or even all three. Here is the one I was planning on keeping, which is a clone of the 260, dubbed the "Architectural Audio Amp 60"
Small chip on the corner, there is another on the same side on the bottom corner. The top looks weird because the flash. Its galvanized steel painted black:
Third one is still in transit (???). Shoot me offers!
I could post alot more that are not bridgeable. As I said, Most home amps are not bridgeable. My point was that it was funny that car guys want to bridge everything, including women. So, that was not a slam, slam. I sold home audio for about 12 years and never had a bridgeable amp in stock. Of course, most equipment was high end.
The amps he is selling here are pretty nice equipment, clean sound, quick on the power. Waiting for a call back on a job and when and if I do get the job, I will snap these up in a heart beat (just 2 though //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif )
I can post more of diff brands that are bridgeable too. I understand what ur saying but just cause I ask if its bridgeable does mean I dont know about home audio. Im just looking for an amp for my moms sub. Heres a lil peak at my home audio to show my taste //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif :
http://i72.photobucket.com/albums/i188/money_25/_MG_6848.jpg
didnt want to clutter this thread so ill leave now
Why wait? They are waiting for you now! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Well, give me a shipping quote to 54153 for 2 of the Sonance versions.
And Slam. With most home speakers, you do not want to bridge unless it is bass. So, you gain about 3db every 100w. But what do you lose when you bridge. SQ and presence. The distortion raises dramatically. Where as bi-amping does the opposite (Slightly but not as dramatic).
Fast1one
Fast1one
California
Fast1one
