Hey guys, I am new to this forum and this is acually my first post! lol. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I bought 2 of these subs off Crutchfield a month ago, and they have been sitting in the boxes in my living room ever since, due to me getting an insane deal on two 15" REs a couple of days after getting these, I never even held these up in the air. I have experienced these subs immense SQ qualities in a local guys install which led me to ordering them and they go real deeeep. And he was putting 1400 rms into each of his and they were happy so these subs are definitely tough. I ordered each of mine for 250 plus shipping, and they are brand new, just have flipped the box hatches to see them. So I will let them go for 250 plus shipping for the pair, enough for me to get started to upgrade my electrical. heres some info on the subs,
# 1,200 watts RMS Rated and tested by the industry standard (no fake power ratings, these are the real deal)
# 12" subwoofer with high excursion so the sub can breathe and not overheat like cheaper subs
# dual 2-ohm voice coils (this has many wiring options)
# These subs are fine tuned, and built for sound quality and raw power! The people who designed these subs are pure audio geniuses!
# woven carbon fiber cones make this sub have the best accuracy and frequency response!
# cast aluminum baskets on this sub help to keep the sub stable and eliminate distortion and other unwanted noises, and will make this sub last longer than other subs on the market
# custom Blaupunkt grille included free of charge!
# Double thick front and back plates gets rid of heat, and keeps the sub cool at all times
# Vented back plates relieves pressure and allows a high cone excursion and keeps the magnet cool
# The nickel spring terminals make sure you have a tight and secure connection to your amp, and it makes sure no power is lost
# All power ratings are EIA-426B Rated and tested, so you can have total confidence that this sub will deliver the power stated or better!
# frequency response: 20-200 Hz
# sensitivity: 90 dB
# Butyl Rubber Surrounds eliminated distortion and enhances stability. This sub only plays pure bass.
# top-mount depth: 7-1/8"
# sealed box volume: 0.5 - 1.5 cubic feet
# ported box volume: 1 - 2.0 cubic feet
Here are the Ts parameters for the subs,
Fs 34 Hz
Qts .41
Qes .44
Qms 5.99
Vas 1.55 CuFt.
Xmax 21 (mm)
Re 4.07(coils in series)
Bl 21.17
Sd 547 Sq cm
Cms 96 (uM/n)
Mms 225 g
thats alot of cone area for 12"s.
and I am willing to separate them. 250 plus shipping for the pair. 125 each plus shipping. peace, oh and pics,
Fs 34 Hz
Qts .41
Qes .44
Qms 5.99
Vas 1.55 CuFt.
Xmax 21 (mm)
Bl 21.17
Sd 547 Sq cm
Cms 96 (uM/n)
Mms 225 g
