Up for sale are a pair of 15" RE SRX with dual 4ohm coils. They look brand new and work 100%. Looking to get $200 shipped for both to the lower 48 or $170 picked up.
SPECS...
* Engineered with new magnet covers that aid in cooling the voice coils while protecting the magnet
* Flat wound voice coils
* Kraft Pulp Cone
* Rubatek Foam Surround
* Pressed Steel Basket
* 4-layer Copper Voice Coil• FEA Optimized Motor Structure
* Double Stack Magnets
* Linear Spiders
* Foam Gasket
* Mounting Depth - 6.75"
* Mounting Hole Diameter - 13.75"
* Overall Diameter - 15.5"
* Bolt Hole Circle - 14.75"
* Motor Width - 6.25"
* Motor Depth - 2.5"
* Basket Depth - 4.25"
* Displacement - 0.16 cu. ft.
* Weight - 17.5 lbs
* QES: 0.45
* QMS: 4.87
* QTS: .41
* Free air Resonance - FS - 23 HZ
* VAS: 203 Liters
* XMAX: 18 MM
* SPL @ 1W / 1M: 87.6 dB SPL
* Effective piston area: Sd: 810 cm ^2
* Dc Resistance: RE: 1.8 ohm
* Nominal Impedance: Dual 4 Ohm
* 300w RMS Rated
* 600 watts max
* Force Factor, BI: 14.35
* Sealed: 1.5 - 2.2 cubic feet (2 cubic feet is recommended)
* Ported: 2.5 - 3.2 cubic feet tuned @ 35 HZ (3 cubic feet is recommended)
SPECS...
* Kraft Pulp Cone
* Linear Spiders
* Foam Gasket
* Weight - 17.5 lbs
* QES: 0.45
* QMS: 4.87
* QTS: .41
* VAS: 203 Liters
* XMAX: 18 MM
* 300w RMS Rated
* 600 watts max
