Sold FS: 2 15" AA Atlas, Crunch 1600.1
Lax916
i have 2 15" AA Atlas's for sale in good condition, Great subs that get loud with little power. Also have a Crunch 1600.1 for sale in good condition. This is a test done with this amp, http://audioforum.termpro.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=20;t=012943;p=0
i would take 100 plus shipping each for the subs and 140 plus shipping for the amp.everything is in great condition only reason im selling is because i sold my truck and now dont have anything to use this in.Might be interested for some trades let me know what you have.
Atlas 15 Specs
Fs 21.5 Hz
Qms 6.56
Qes .392
Qts* .37 - 1.05
Vas 364 L
Re 2.8 ohms
Znom 4 ohms
Xmax 18 mm
Sd 810 cm2
Mms 139 g
Vd 2.91 L
Pnom 300 watts
Le .86 mH
Cutout 14.125"
Diameter 15.5"
Depth 7.25"
Weight 24 pounds
*Adjustable
they are for all practical purposes SVC 4ohm, but they do have a DVC setup, the 2nd coil is a 2ohm coil simply for adjusting the qtc of the sub. You cannot power the 2ohm coil. If you have two you can wire them up as a triplet of 4ohm coils however because two of the 2ohm coils in series can then be powered as a 4ohm coil (giving you three 4ohm coils)
yea might be interested in trades, let meknow what you got
I have alot of old school gear..such as...
Subs:
10" PPI Pro Flat Piston (2)
15" PPI Pro Flat Piston
JL 10w6v2
Amps:
US Amps US-100HC...a beast
Rockford 250a2 (2)
Rockford 200a4
PPI Art Ax400
PPI 2075M
etc.
Lax916
Lax916
Orlando, FL
Lax916
