Sold FS: 2 12w6v2
daicacharco
i have 2 12'' JL w6v2 for sale.
*225 + shipping for one.
or
*485 + shipping for 2
it'll come with original box.
SPECS
Free Air Resonance (Fs): 25.0 Hz
Electrical “Q” (Qes): 0.480
Mechanical “Q” (Qms): 7.100
Total Speaker “Q” (Qts): 0.450
Equivalent Compliance (Vas): 2.82 cu. ft. / 79.9 liters
One-Way, Linear Excursion (Xmax)*: 0.65 in. / 16.5 mm
Reference Efficiency (no): 0.250%
Efficiency (1W/1m)**: 85.9 dB SPL
Effective Piston Area (Sd): 77.8 sq. in. / 0.0502 sq. m.
DC Resistance (Re): 6.75 ohm***
Nominal Impedance (Znom): Dual 4 ohm
Thermal Power Handling (Pt): 400W
Driver Displacement: 0.090 cu. ft. / 2.5 liters
Net Weight: 19.4 lbs. / 8.8 kg
DATA CHART
Brand: JL Audio
Model: 12W6v2-D4
MSRP: $459.95
Warranty: 1-year dealer installed or approved, otherwise 90 days
Mechanical Specifications
Weight: 23 lbs.
Rear Mounting Clearance: 7.062"
Woofer Magnet Dim. (dia. X ht. in mm): 167 x 40
Voice Coil Diameter: 69.85mm (2.75")
Voice Coil Winding Layers: 2x2 (two, two-layer coils)
Measured T/S Parameters
Nominal Impedance (ohms): 8
Revc (ohms): 6.58 (both 3.3-ohm voice coils connected in series)
Sd (cone area in sq. meters): 0.050
Bl (motor strength in Tesla Meters): 20.4
Vas (in liters): 83.8
Cms (micrometers per Newton): 23.8
Mms (grams): 181.7
Fs (Hz): 24.3
Qms: 7.52
Qes: 0.44
Qts: 0.42
Power and Excursion Data
Sensitivity (2.83V/1M in dB): 87.3
Continuous Power Handling (Watts RMS): 400
Peak Power Handling (Watts): Not published
Xmax ([coil length - gap height]/2 in mm): 16.5
Hmm..looks like I was a minute to late with this info.
daicacharco
daicacharco
San Diego. CA
daicacharco
