You are bidding on a 1U Supermicro SuperServer 6014H-T (B) 64-Bit Complete System!
The system was pulled from a working environment and only saw a few months of continuous use! Never had one problem with the system and will work flawlessly upon delivery!
Specifications:
» Processors: 2 x DUAL INTEL XEON 3.0GHZ 64BIT EM64T 800FSB 1MB CACHE
» Motherboard: SUPERMICRO X6DHR-TG
o Dual Intel® 64-bit Xeon® Support, up to 3.80 GHz, 800 MHz FSB
o Intel® E7520 (Lindenhurst) Chipset
o Up to 16GB DDR 333 SDRAM (or) Up to 32GB DDR 266 SDRAM
o Intel® 82546GB dual-port Gigabit Ethernet Controller
o Adaptec 4-Port SATA Controller
o 2x SATA Ports via ICH5R SATA Controller
o 2 (x8) PCI-Express, 1x 64-bit 133MHz PCI-X, 1x 64-bit 100MHz PCI-X
o IPMI 2.0 Socket
o Zero Channel RAID Support
o Supermicro IPMI Card (AOC-IPMI20-E) INCLUDED!
» RAM: 4096MB DDR 333 ECC REG LP (4 x 1024MB)
» Hard Drives: 4 x WESTERN DIGITAL 250GB 8MB SATA HOT-SWAP 1 TERABYTE!
» RAID Controller Card: 3Ware 8506-4LP 4 PORT SATA RAID
» Floppy Drive: TEAC 3.5” 1.44MB Slim Floppy Drive
» CD-ROM Drive: TEAC Slim 24x CD-ROM Drive
» Chassis: 1U SUPERMICRO SC813T-500 (500W PS, 4 HOTSWAP HDD, RAIL KIT)
» Power Supply: 500 WATT Cold-swappable AC PC with PFC
» HD Bays: 4x 1” HOTSWAP SAS / SATA BAYS
» Heat Sinks: 2 x 1U INTEL XEON SUPERMICRO SNK-00009
» Fans: 2x 10cm Blower Fans
» Dimensions:
o Height: 1.7” (43mm)
o Width: 17.2” (437mm)
o Depth: 25.6” (650mm)
» Warranty: Cross-Ship Advanced Replacement Warranty from Supermicro
Supermicro slide rails, mounting brackets included.
Buy it now for : $2,879.00 + Shipping!
Bid Now: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=9705648669
Specifications:
o IPMI 2.0 Socket
» Dimensions:
