w0lv3121n3
I have a Mint 17" LCD Monitor for sale.
NEC LCD1712.
Everything is in Mint condition and works amazing.
Looking to get $180 + shipping.
I have pictures for anyone who would be interested.
Thanks
Product Features
* 1,280 x 1,024 maximum resolution, 0.264 mm dot pitch
* 140-degree horizontal and 120-degree vertical viewing angles
* 250 cd/m2 of brightness, 450:1 contrast ratio
* 16 ms response time for smooth motion video
* PC and Mac compatible; 3-year warranty
Technical Details
* Compatibility: PC and Mac
* Panel type: Active matrix TFT LCD
* Display size: 17"
* Diagonal viewable screen size: 17"
* Dot pitch: 0.264 mm
* Contrast ratio: 450:1 (typical)
* Brightness: 250 cd/m2 white luminance (typical)
* Glass surface: Coated, reduced glare
* Horizontal viewing angle: 140 degrees
* Vertical viewing angle: 120 degrees
* Display colors: 16.2 million (dependant upon display card used)
* Response time: 16 ms (typical)
* Input signals: Analog 0.7 Vp-p/75 Ohms Positives
* Input connector/cable: D-sub to D-sub cable
* Maximum resolution: 1280 x 1024
* Supported resolutions: 720 x 400 at 70 Hz, 640 x 480 at 60 Hz to 75 Hz, 800 x 600 at 56 Hz to 75 Hz, 832 x 624 at 75 Hz, 1024 x 768 at 60 Hz to 75 Hz, 1280 x 1024 at 60 Hz to 70 Hz, NOTE: Some systems may not support all modes listed
* Horizontal frequency: 31.5 kHz to 81.0 kHz
* Vertical frequency: 56.0 Hz to 75.0 Hz
* Active display area: 13.3" x 10.6"
* Storage temperature: 14 degrees F to 140 degrees F
* Storage humidity: 10% to 85%
* Altitude: Up to 30,000 feet
* Sync, separate: TTL level
* Sync, horizontal: Positive/ negative
* Sync, vertical: Positive/ negative
* VESA wall mount: Yes, 100 mm
* Regulatory approvals: UL/C-UL or CSA, TUV/GS, Energy Star, CE, FCC Class B/Canadian DOC, TUV/Ergonomie, Windows CE/XP
* Power management: VESA DPMS
* Power consumption, on: 38 W
* Power consumption, power save: Less than 3 W
* Current rating: 0.8 A @ 100 - 120 V / 0.4 A @ 220 - 240 V
* Power supply: AC 100-120/220-240 V @ 50/60 Hz
* Width, with stand: 14.7"
* Height, with stand: 14.8"
* Depth, with stand: 7.9"
* Width, without stand: 14.7"
* Height, without stand: 12.9"
* Depth, without stand: 2.3"
* Weight: 9.9 pounds
* In the box: Monitor, base, user's manual, power cord, signal cable, setup sheet
I also have a Sony MDR-V700DJ Headphones for sale.
These are DJ Headphones, Sounds incredible.
Mainly used to practice guitar at night.
$70
If anyone is interested, I can send them pictures of the headphones or the monitor.
Thanks
NEC LCD1712.
Thanks
Product Features
Technical Details
* Display size: 17"
$70
Thanks
