For sale: 15" RE SX Dual 2 ohm. This is the original RE SX (not the new SXX). Very nice sub and has been treated extremely well. Ran off 800rms for ~6 months. Been sitting in the basement for a while and decided its time to get rid of it. Looking for $165 Shipped! May consider trades. Just let me know what you have. Any questions let me know. Thanks!
-Nick
■Thermal Power Handling -Pe: 1000 W
■Force Factor -Bl: 21
■Electrical Q Value -Qes: .38
■Mechanical Q Value -Qms: 4.7
■Total Speaker Q Value -Qts: .38
■Free Air Resonance -Fs: 27.8 Hz
■Equivalent Compliance -Vas: 126.3 liters
■One-Way, Linear Excursion -Xmax: 22 mm
■Efficiency - SPL 1W/1m: 90.4 dB SPL
■Effective Piston Area -Sd: 810 cm^2
■DC Resistance -Re: 1.9 ohm
■Mounting Depth - 7.75”
■Mounting Hole Diameter - 14”
■Overall Diameter - 15.5”
■Bolt Hole Circle - 14.75”
■Motor Width - 6.5”
■Motor Depth - 3.25”
■Basket Depth - 4.5”
■Displacement - .18 cu. ft.
■Weight - 27 lbs.
■Dual Composite 2-piece Cone
■Rubbertek Foam Surround
■Cast Aluminum Basket
■Tork-Tite Terminal
■3 " 8-layer Aluminum Voice Coil
■FEA Optimized Motor Structure
■Triple Stack Maganets
■Progressive Spiders
■Wrap around Rubber Gasket
-Nick
■Motor Width - 6.5”
■Weight - 27 lbs.
■Tork-Tite Terminal
