Sold FS: 15"L7, Clarion Head Unit, Fusion 1600rms
Cmccloud
Hey everyone I just thought I would try to sell some stuff to fund a new system. I want to go with a 3 or 4 15" Setup so this stuff has to go.
First I have a Clarion DXZ945MP. One of the nicest head units I have owned, little too complicated for me though, lol. Works great Cosmetically 9/10 Mechanically 9/10 No remote
http://www.clarion.com/us/en/products/2005/audio/source_units/cd/DXZ945MP/us-en-product-pf_1133851137416.html
* Motorized Detachable Face
* Plays CD-Rs and CD-RWs
* Plays MP3- and WMA-Encoded Discs
* Optimedia Display
* Touch-Panel Control
* 16-Gradation Full-Dot LCD
* AC-Processor III With ADF
* Dolby Pro Logic II
* CeNET Control of Optional Dolby Digital/dts 5.1 Processor, TV Tuner, Sirius Satellite Radio Receiver, DVD and CD Changer
* CeNET B.B. (EA1251B) iPod Control
* CD Text, CD and Station Titling
* IR Remote Control
* 24-Bit D/A Converter
* 3-Band, 1/3-Octave Parametric EQ
* Built-In DSP for Time Alignment, Seat Position, Virtual Space Enhancer
* 4-Volt/6-Channel Gold-Plated RCA Line Level Output
* One 2-Channel Aux. Input
* Built-In Adjustable High-Pass Crossovers for Front/Rear/Center Channels: Through/50Hz/80Hz/120Hz
* Built-In Adjustable Low-Pass Crossover With Subwoofer Volume Control: 50Hz/80Hz/120Hz
* 2 Zone Control With Dedicated RCA Line Level Outputs
* Adjustable Display Contrast
* 212 Watts (53 Watts × 4 Channels)
* Radio Tuner With 18FM/6AM Presets
* Screen Saver With User-Programmable Message Information
* Blinking LED for Anti-Theft
* iPod Control (Requires EA1251B / CeNET iPod Interface)
I have a Fusion FJL-1611D. This amp is in pretty good shape, has a few scratches on it but works good. For some reason when I put the L7 in 1 ohm it puts the amp in protect mode but at 4 ohm it works great not sure what that is all about. I know it still makes the L7 sound good even in 4 ohm mode.
http://www.anythingwholesaleaz.com/index.asp?PageAction=VIEWPROD&ProdID=749
Detailed Description
1 Ohm / 2 Ohm Stable Linked
CEA 2006 Amplifier Power Standard Compliant
FUSION Regulated Amplifier Technology (F.R.A.T)
FUSION Intercooled Semi-conductor Technology (F.I.S.T)
FUTRANZ Efficient Heat Sink Transfer Technology
Gold Plated 4 gauge Power and Ground Connections
Gold Plated Audio Input and Output Connections
Gold Plated RCA Output for Multi-purpose installations
F-BASS Remote Controller Compatiable
Product Specifications
Bandwidth 10Hz - 50kHz
Signal to Noise >95dB
Fuse Rating 4 x 30A
Separation >60dB
Input Sensitivity 300mV-8V
LP Variable Crossover 40 Hz - 240Hz @ 24 dB / octave
HP Variable Crossover 40 Hz - 240Hz @ 24 dB / octave
Variable Bass Boost 0dB + - 18dB Gain @ 45 Hz
Variable Sub Sonic Filter 10 Hz - 55Hz @ 18dB / octave
Input Impedance 20K
Damping Factor >200
T.H.D 0.06%
Dimensions D 65.5mm L 468mm H 276mm
CEA 2006 Compliant Amplifier Ratings
12.6 Volt Power Output Specifications
600 WRMS per Channel @ 4 Ohms and 1% THD+N
900 WRMS per Channel @ 2 Ohms and 1% THD+N
1250 WRMS Bridged Channels @ 4 Ohms and 1% THD+N
14.4 Volt Power Output Specifications
840 WRMS per Channel @ 4 Ohms and 1% THD+N
1250 WRMS per Channel @ 2 Ohms and 1% THD+N
1600 WRMS Bridged Channels @ 4 Ohms and 1% THD+N
Linked Power Ratings @ 14.4VDC
2850 Watts RMS Linked @ 4 Ohms
3400 Watts RMS Linked @ 2 Ohms
Up for trades but mostly looking for cash.
Clarion DXZ945MP-$200
Fusion FJL-1611d-$250
Will have pics up tomorrow
Cmccloud
Cmccloud
LaFollette, TN
swoosh
