four re se 12's in a silverado extended cab
thur5d4yf4n
sorry no build pictures yet, i already have two of them dual 4 with an american bass vfl 150.1 gold series. im ordering two more this week when my paycheck clears.
so i started doing the box design and so far i've come up with:
remove rear bench
3/4" Mdf
8.5 cubes after port and sub displacement
2 six inch aero ports flared tuned to 32 hz
subs firing up to the roof
ports firing in the middle of the box towards front of the truck
58" wide 23" deep 15" tall
electrical
stock 130? (IIRC) amp alternator
2 gauge single run power
yellow top under the hood
(open to suggestions on this setup i think it might need to be beefed up)
before i begin the build in scorching hot AZ (113 degrees-120 degrees during the day //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif) i want to make sure with everyone that the plans look okay.
enough port area? enough volume? bracing? tuning alright? sub and port placement? all you silverado guys please chime in that have done similar builds! thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
here's some pictures of 1 of the se's
Those RE SEs will handle some power man, I had 900watts to each of mine at one point. They loved about 750watts for daily though...
right now im running two of them on the vfl 150.1 at 1 ohm load and the amp was on half power with the gains and i can get them to slam super hard but they do distort at high volumes still.
thur5d4yf4n
thur5d4yf4n
Glendale, AZ
thur5d4yf4n
