LeofromtheH
sneaker head
ok so i'm contemplating on doing a setup with 4 p2 12's, which will either go in an '03 tahoe or '98 silverado ext. cab(most likely). i've already got two p2 12's so i thought i'd just pick up another pair and call it a day.
i've also got a kac-8152d that does 550x1@2 ohms two power all four.
so since each 12 will be svc8 ohm, final ohm load will be 2ohms,
Q:will running four subs off of a mono amp be too much for the amp? even though it will be at a stable 2 ohms?
also, the subs specs reccomend 1.75each @ 37hz.
Q:does is matter if i were to put each sub in their own box? or can i say, put a pair in each chamber.
Q:if i were to put a pair in each chamber, would the tuning/port size of 37hz remain the same as putting a single sub in its own enclosure?
