Four 8" PA 860's sealed
volonau
I have four Planet Audio P-860 (4 ohm each) ebay specials running in a 3 cubic foot box sealed.(all together)
They are run in series and then in parallel=4ohms.
The strange thing I've noticed while watching them move is that the two woofers connected to the positive on the amp move together and the other two that are connected to the negative of the first woofers voice coil move together.
Now would this not mean that there is a time delay to the second woofers because of having to run through the first woofers voice coil ?(cancellation issues)
If above statement is correct then wouldn't there be an advantage to buying higher impedance woofers and running them all in parallel as apposed to lower impedance woofers running in series?
series wiring between different woofers can affect drivers due to emf..
its always best to keep the series wiring to a single woofer, if its a dvc.. and not series together multiple woofers..
I fought this battle with my 8's..
Loyd L.
volonau
volonau
Cupar,Sask
bigbassman
