This amp really does push. It doesnt push 900rms in 2 ohms it more around 800 rms. Great condition. Still have Manual & orignal box. Im also throwing in 40 amp fuse in case if the fuse ever blow (which it hasnt yet). Amp is about 3.5 years old. Been in my closet for almost 2 year. I test it last week, it push 9500 just fine. Asking $100 + shipping I'll throw in 1.0 Tsunami Caps for $30 more. I know they are useless. But who cares //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
No hater or low baller. //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
Amp spec.
Sony XMD1000P5
1600W max power @ 2 Ohms
1000W max power @ 4 Ohms
500W x 1 RMS into 4 ohms, 20Hz - 100Hz at 0.2% THD
900W x 1 RMS into 2 ohms, 20Hz - 100Hz at 0.6% THD
Class D
Variable 50 - 300Hz Low Pass Filter
Frequency Response: 5 Hz - 300 Hz (±3dB)
Harmonic distortion: 0.06% or less (at 100 Hz, 4 ohms)
Input level adjustment range: 0.3 - 6V (RCA pin jacks), 1.2 - 12V (High level)
Low-pass filter: 50 - 300 Hz, -12 dB/oct
Low boost: 0 - 10 dB (40 Hz)
40Hz EQ boost
Line level throughput
MOSFET output stage & power supply
Input/Outputs:
Inputs: RCA pin jacks, High level input connector
Outputs: Speaker terminals, Through output pin jacks
Pulse Power supply
Speaker Impedance: 2 - 8 ohms (stereo)
Power requirements: 12 V DC car battery (negative ground)
Power supply voltage: 10.5 - 16 V
Current drain: 50 A (at 4 ohms, rated output)
Dimensions (W x H x D): 13 11/16" x 2 1/4" x 13 7/8" (347mm x 57mm x 339mm)
Weight: 8 lbs 6 oz (3.8 kg)
Amp spec.
Sony XMD1000P5
Class D
40Hz EQ boost
Input/Outputs:
Pulse Power supply
