Sold For Sale: SX-SLII - Zapco Premium Pre-Amp/EQ/Crossover
SPANKYSPL
$230.00 PLUS SHIPPING
SymbiLink™ Preamp/EQ with Adjustable 3-Way Crossover, Fader and Lows to Highs Balance
-SymbiLink™ balanced input and outputs
-Five paragraphic equalizer filters
-Front/rear fader
-Frequency balance control
-Two or three way electronic crossover
-Retractable control knobs
-12 or 24 dB per octave slope on the subwoofer
output
-12 or 18 dB per octave slope on the X1 crossover
-Times ten range switch on X2
-10 dB boost switch on the subwoofer output
-0, 6, or 12 dB gain switch on input
-Balanced or unbalanced input switch
-Changeable illumination color
-Isolated power terminal for illumination
-Optional PSI-HPSL external power supply
-Quality Zapco construction
-Precision 1% tolerance resistors used throughout
Max Output Level: 16 volts RMS
Balanced:12.5 volts RMS
Input Impedance: 3k ohms
Max Input Level: >110dB
S/N Ratio A Weighted (EQ In, All Outputs):
+0, -0.25db 20Hz
Frequency Response: >80dB
Crossover Frequencies: Variable -30Hz to 1KHz
Sub Out: Switchable 12dB or 24db; Variable -40 Hz to 600Hz
High Pass (xl): Switchable 12dB or 24dB, Variable -40 Hz to 600Hz
High/Band Pass: Switchable 12dB or 18dB, Variable -40 Hz to 600Hz
Dimensions: 5.25"D x 6.25"W x 0.95"H
hi there
is your eq new or used ? how many channel ? can you post a back pic of an eq ? how much for the shipping if you ship to virginia and how can i make pay for it ?..... sorry i'm new here..... thanks
SPANKYSPL
SPANKYSPL
Austin, TX
super_duper
