Rare Black JL Audio 1000/1 and 450/4
Both items are used, but very little and are in MINT condition. The only marks on either are around the mounting holes.
Specs:
1000/1
Amplifier Topology: H-Bridge, Class D Mono
with impedance optimization and patented
discrete drive circuitry
Power Supply: Pulse width modulation-regulated
switching power supply
Rated Power: 1000W RMS x 1 @ 1.5 - 4Ω (11 - 14.5V)
THD at Rated Power:
Signal to Noise Ratio: >95 dB referred to rated power
(A-weighted, 20 Hz - 20 kHz noise bandwidth)
Frequency Response: 5 - 250 Hz (+0, -3 dB)
Damping Factor: >500 @ 4Ω/50 Hz, >250 @ 2Ω/50 Hz
450/4
CHANNELS 1 & 2:
Amplifier Topology: Class AB with patented Absolute
Symmetry™ dual N-Channel MOSFET output design
Power Supply: Independent, pulse width modulationregulated
switching power supply with multistage
impedance optimizing circuitry.
Rated Power (Stereo):
150W RMS x 2 @ 1.5-4Ω (11V - 14.5V)
Rated Power (Bridged):
300W RMS x 1 @ 3-8Ω (11V - 14.5V)
THD at Rated Power:
(20 Hz-20 kHz)
Signal to Noise Ratio: >108.5 dB referred to rated power
(A-weighted, 20 Hz-20 kHz noise bandwidth)
Frequency Response: 5 Hz - 30 kHz (+0, -1dB)
Damping Factor: >200 @ 4Ω per ch. / 50 Hz, >100 @ 2Ω
per ch. / 50 Hz
Slew Rate: ± 25V/μs
CH 1&2 Filter: State-variable, 12 dB/octave Butterworth or
24 dB/octave Linkwitz-Riley Low-Pass or High-Pass with
continuously variable cutoff frequency from 50 - 500 Hz,
switchable to a range of 500 - 5000 Hz, via x10 switch.
Can also be cascaded from Channel 3&4 filter’s cutoff
frequency to operate as a bandpass filter for tri-amp
configurations. Defeatable.
LF Boost: Single-band, fixed-frequency (48 Hz), fixed “Q”
+6 dB boost. Defeatable. Port for optional remote bass
control to provide variable boost control from 0 to +15 dB.
CHANNELS 3&4:
75W RMS x 2 @ 1.5 - 4Ω (11V - 14.5V)
150W RMS x 1 @ 3 - 8Ω (11V - 14.5V)
THD at Rated Power:
(20 Hz - 20 kHz)
Frequency Response: 5 Hz - 30 kHz (+0, -1 dB)
per ch. / 50 Hz
Slew Rate: ± 25V/μs
Channel 3&4 Filter: State-variable, 12 dB/octave
Butterworth or 24 dB/octave Linkwitz-Riley High-Pass with
$1000 shipped OBO. Don't be afraid to make an offer.
Will ship to the continental US only. If you want it shipped outside the US, you will be responsible for handling all shipping arrangements and costs.
Specs:
1000/1
THD at Rated Power:
450/4
CHANNELS 1 & 2:
THD at Rated Power:
(20 Hz-20 kHz)
per ch. / 50 Hz
Slew Rate: ± 25V/μs
CHANNELS 3&4:
THD at Rated Power:
(20 Hz - 20 kHz)
per ch. / 50 Hz
Slew Rate: ± 25V/μs
