Sold For Sale: Lightning Audio Storm V1 (TC-3,000) 12" 1.25 Sealed Box CHEAP!
mike11202
Up for sale is a Lightning Audio Storm x1.12.vc2, 1000rms 3000max, Dual 2, .4-1.2 cu ft. rec. sealed.. 1.5-2.5 cu ft for ported.
edit $130 shipped
(remember this has the TC-3,000 motor on it)
Its cracked in 2 spots see pictures below, but since I've been running it, it works fine and does not affect performance at all.
This thing will SLAM the lows like no other in a ported box tuned around 32hz, and will have a very flat response in sealed.
About the perfect SQL sub.
I had a Soundsplinter RL-S 12" awhile ago and this was a little louder and close to the same SQ. Plus its Dual 2ohm VC, so easier on the amps.
review:
http://www.carsound.com/articles/publish/article_190.shtml
Second we have a 1.25 cu ft. wedge sealed box for a 12", made out of Lightweight 3/4" MDF (only weighs about 20lbs!) I have it stuffed with polyfil, you can take it out if you want. Carpeted Black.
Height 13" x Length 16" x Top Depth 12" x Bottom Depth 15.5"
Very small, will not take up much space at all //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
$65 shipped
can you still get the top assemblies (if they work for these) from TC Sounds (I mean Audio Pulse)?
they will work and gl getting another la storm top assy. not saying you cant but thilo is a bish to get ahold of.
you can find used ones tho //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
mike11202
mike11202
DE
mike11202
