Sold For Sale: Lightning Audio 150.2, Visonik V500HC, Infinity 5000cs comps
ronjon228
Well I've decided to rework my entire audio setup so I'm selling off all my current stuff. All equipment is 100% working as new, with cosmetic blemishes being noted for each item. PRICES ARE NEGOTIABLE AND I WILL CONSIDER ANY REASONABLE OFFER!!!
Shipping will all be through FedEx as I work there and will be top quality packaging. Also, because I work at the terminal I can get these out same day most cases, next day guaranteed. They will be shipped directly from the terminal which usually cuts down on transit times, and tracking ID's will be issues right away. My cost for shipping will be ~ 8 USD. That's the reason for the odd prices. I'm only charging actual cost for shipping.
I don't have any CA references, but as you can see, I'm a LONG time member. If you need feedback for me check out http://www.overclock.net (user ID darcness) or Ebay (user ID brushlessae).
First up, my Lightning Audio Bolt 150.2 Amplifier - Asking $38 shipped.
Model number is B150.2. The amp is in overall good cosmetic condition. The only blemishes on this amp are small scratches and a scuff on the top left portion (as you see on the pics). These flaws are only cosmetic and all the adjustments, inputs, and switches still work as new. It was installed on an amp rack, never ran at lower than 4ohms, and not abused in any way. Before shipping it will be cleaned as it has some dust/dirt from being in the trunk.
Link to specs: http://www.crutchfield.com/S-d6Vi06mRswE/App/Product/Item/Main.aspx?i=495B1502
Next is my Visonik V500HC Amplifier - Asking $78 shipped.
This is an unregulated power supply amplifier. With a 1ohm bridged load, it will do 500x2 RMS watts. It's been running my component set (at 4ohms on front channel) and my 2 Pioneer 305DVC's (at 1ohm on rear channel) for about a year now and it sounds great. I've never had it shut off or overheat and it's always been treated well. It was installed on an amp rack to keep it from moving around in my trunk as well. Cosmetically it's nearly perfect condition. All the adjustments, knobs, and switches on this amp work it did when it was new as well. The cooling fan does make a bit of noise on start up, but clears up soon after. As with the LA amp, I'll be cleaning this amp before shipping. It has some dust/dirt on it from being in the trunk.
Link to specs: http://www.dealtime.com/xPF-Visonik-V500HC
Next, my Infinity 5000cs 5.25" Component set - Asking $58 shipped.
The Infinity comps are in perfect condition, both driver and tweeters. The crossovers are 100% like new in terms of operation, but the terminals from being in my door have surface rust on them. The contacts look bad, but they are all tested to be working, including the -3db setting for the tweeters. I also replaced 2 of the terminal screws as they were stripped out. You can see this in the picture of the crossovers with the covers removed.
Other than the contacts, this set is in near mint condition with no blemishes or damages on the speakers, or tweeters. The tweeters will come with the surface mounts shown in the picture. This component set was used for about 1-1.5 years in my Regal, running with 50x2 watts @ 4ohms and never gave me a single problem. They still sound fantastic and I've never had any problems with them.
Link to specs: http://www.bargainsnest.com/Infinity-5000cs-525-2-Way-Component-Speakers_p_7-118.html
Lastly, a set of Stinger Hyper 4-channel Interconnects (17ft) - Asking $23 shipped.
If anyone is looking for some nice RCA's I also have a set of stinger 4-channel @ 17ft. They are the Hyper series interconnects. No pictures of my exact set as it's still in my buddies WRX, but he just added a CarPC and won't be needing them. I'll take them out when/if they are sold.
Link to specs: http://cgi.ebay.com/STINGER-Hyper-Series-20-Foot-RCA-Cable-4-Channel-NEW-05_W0QQitemZ250217592845QQcmdZViewItem (please note this is NOT my listing)
ronjon228
ronjon228
Michigan
ronjon228
