For sale-
kole audio kx1-5500d: used less than 2 months.
KX Series Class D Monoblock Car Amplifier
RMS Power Rating:
4 ohms: 1700 watts x 1 chan.
2 ohms: 2500 watts x 1 chan.
1 ohm: 3200 watts x 1 chan.
Max power output: 5500 watts x 1 chan.
Fully regulated PWM MOSFET power supply
Wired remote bass level control included
LED power and protection indicators
Tuned Bass EQ (0-18 dB bass boost at 45 Hz)
High speed digital circuitry
Bridging synchronization capable
Preamp RCA outputs
4-way Protection circuitry
System distress indicator
1 ohm Stable
Nickel-plated screw terminals
Variable low-pass filter (50-150 Hz)
Subsonic Filter (60-200 Hz)
Frequency response: 15-150 Hz
Dimensions: 17.5"L x 11.7"W x 2.2"H
4/8-gauge power and ground leads recommended. Contact us for information regarding a discount on a select amplifier kit when purchased together.
1-year Manufacturer's warranty
Amplifier Specifications:
Amplifier Class: D
Number of Channels: 1 - Mono
RMS Power (4 ohms): 1700 watts x 1 channel
RMS Power (2 ohms): 2500 watts x 1 channel
RMS Power (1 ohm): 3200 watts x 1 channel
Bridged RMS Power: Not Bridgeable
Peak Power Output: 5500 watts x 1 channel
Minimum Impedance Unbridged: 1 ohm
Minimum Impedance Bridged: Not Bridgeable ohms
THD at Rated RMS Power: .5%
Speaker Level Inputs: No
Amp Preamp Outputs: Yes - 1 pair
Built-in Crossover: Low-pass (LP)
High-Pass Crossover Frequency: N/A
Low-Pass Crossover Frequency: 50 - 150 Hz
Subsonic Filter: 15 - 40 Hz
Signal-to-Noise Ratio: 100 dB
Channel Separation: N/A
Bass Boost: 0 - 18 dB
Bass/Gain Remote: Yes
Fan Cooled: No
Fuse Rating: 30A x 5
Warranty: 1-year Manufacturer's
2 15" orion hcca with boxes. Boxes are 1" mdf in black carpet, 2.89cf each and tuned @ 36.75 hz, and were built by finecustomaudioworks.
Power(RMS/Peak) 2000/4000
Fs (Hz) 31
Qts .59
Vas (cu ft) 2.629
SENSITIVITY 87db
LINEAR EXCURSION 30mm
DIMENSIONS (in) 15.6x12
Subs have a few light scratches on them because it was a tight fit getting em' in the car at first, but they are in perfect condition.
Everything is best offer, so send me a pm with your offer. I will ship these, but if you want you can come and listen to this stuff in person before ya buy it.
RMS Power Rating:
Preamp RCA outputs
1 ohm Stable
Amplifier Class: D
Fan Cooled: No
Fs (Hz) 31
Qts .59
Vas (cu ft) 2.629
SENSITIVITY 87db
