For sale are 2 JBL amplifiers. The GTO 14001 & GTO 504. They both come in the original boxes with the instructions, etc. The GTO 14001 comes with the bass knob. They both work perfectly and sound great. The GTO 504 has a tiny scratch on the mounting bracket but that's it. Otherwise both this amps are in excellent condition. 9/10 easily if not better. Asking $350 shipped firm. The specifications on both amps are listed below.
The GTO14001 has been engineered to ensure optimum power delivery into numerous impedances with low distortion. It comes outfitted with a variable 12dB per octave electronic crossover allowing you to optimize subwoofer tuning based on location and accompanying loudspeaker components. It also includes JBL's Dynamic Bass Optimization Circuit which provides variable filtering with adjustable Q below 100Hz. This circuit allows turing of any enclosure to any vehicle. Full range preamp outputs are provided facilitating multiple amplifier hookups without the need for high-loss Y-adapters or signal splitters.
The GTO14001 also features direct connect, which allows use of up to 4-gauge power and ground cable to ensure enough juice is being delivered. Direct connect speaker terminals are also used eliminating the need for additional adapters or special fittings. Common-dimension amplifier footprints are used on all of the GTO models providing two common dimensions for ultra clean multiple amplifier model installations.
Description:
JBL GTO 14001 Grand Touring Series Class AB Monoblock Car Amplifier
RMS Power Rating:
4 ohms: 1200 watts x 1 chan.
2 ohms: 1500 watts x 1 chan.
LED power and protection indicators
Tuned Bass EQ (0-12 dB bass boost)
Preamp RCA outputs
Cast-aluminum heatsink
JBL patented DBOC (Dynamic Bass Optimization Circuitry)
Variable low-pass filter (32-320 Hz, 12 dB/octave)
CEA-2006 compliant amplifier
THD at Rated RMS Power: 0.05%
Low-Pass Crossover Frequency: 32 - 320 Hz
Signal-to-Noise Ratio: 108 dB
Fuse Rating: 40A x 4
Frequency response: 20-330 Hz
Dimensions: 18-9/16"L x 10-3/8"W x 2-1/8"H
GTO 504
Grand Touring Series 4-Channel Class AB Car Amplifier
RMS Power Rating:
4 ohms: 55 watts x 4 chan.
2 ohms: 70 watts x 4 chan.
Max power output: 140 watts x 4 chan.
Tuned Bass EQ (0-6 dB bass boost)
Preamp RCA outputs
Variable high-pass filter (32-320 Hz, 12 dB/octave)
Frequency response: 10-100000 Hz
Dimensions: 13-3/16"L x 10-3/8"W x 2-1/8"H
I do not ship outside the United States.
Description:
RMS Power Rating:
Preamp RCA outputs
GTO 504
RMS Power Rating:
Preamp RCA outputs
