Sold For sale digital designs m1a
cleansoundzz
For sale is a Digital Designs M1A mono-block amplifier. This amp was purchased from an authorized DD dealer brand new 1 month ago as a display model and it works perfectly and is in excellent condition. I would rate it a 9/10 easily if not better. Here are the specs for the amp.
Features:
Two Amp Linkable
High level inputs can be fed into RCA's
Terminal block power & speaker connections
Clipping indictator
Thermal protection
Reverse polarity protection
Speaker short protection
Low & High voltage protection
on/off Crossover Selector
Specifications
Input Sensitivity 0.2V - 8V
Variable High Pass Filter -
Subsonic Filter 10 Hz - 50 Hz at 24 dB/Oct
Variable Low Pass Filter 20 Hz - 200 Hz at 24dB/Oct
Clipping Display LED
Tested Voltage 14.4V
Tested THD 1%
Cont Power at 4 ohm 300W x 1ch
Cont Power at 2 ohm -
Damping Factor >250 @ 1 ohm
Cont Power at 1 ohm 1200W x 1ch
Cont Power at 4 ohm Mono 300W x 1ch
Cont Power at 3 ohm Mono -
Dynamic Power 2300W x 1ch
Efficiency thru Output >75%
Dimensions - mm 300 L x 235 W x 53.4 H
Signal to Noise 85 dB
Shipping Weight 12 lbs (5.443Kg)
Asking $225 shipped firm, no trades.
cleansoundzz
cleansoundzz
Buena Park
cleansoundzz
