AudioQue AQ1200
Excellent condition, used this to power 2x IDQ12 V4's and its been great.
SQ series amplifiers are fully stable down to one ohm.
Daisy Chain connection of two amplifiers stable down to 2 ohms
Four way protection circuits: Speaker shorts, DC offset, High/Low voltage, Thermal protection
Double sided boards with high current MOSFET switching devices
24db/oct slope crossovers, Fully adjustable Low Pass Filter and Subsonic Filter
Specifications
Model AQ1200D
Frequency Response 20Hz—250Hz
Signal to Noise Ratio 100db
Low Pass Crossover 24db / Oct
Low Pass Crossover Range 20Hz—200Hz
Subsonic Crossover Range 10Hz—50Hz
Input Sensitivity 0.2V—8V
Output Master / Input Slave Connection Yes
Working Voltage 8V---16V
Efficiency @ 4 ohm 84%
Damping Factor Less than 150
Fuse Rating 40Amp X 3 (Linked 240 Amp)
Output Power 14.4V @ 1% THD 510X1 @ 4 ohm,870X1 @ 2 ohm,1200X1 @1 ohm
Output Power 14.4V @ 5% THD 1470X1 @ 1 ohm
Dimensions 12.75"(L)x9.27"(W)x2.35"(H)
$100
Shipping not included. Should run like $10
https://www.dropbox.com/s/g4wyttvok1dkaba/IMG_0477.JPG?dl=0
https://www.dropbox.com/s/fv7n487saavrrdg/IMG_0475.JPG?dl=0
https://www.dropbox.com/s/mo5km20gu5f2hyt/IMG_0476.JPG?dl=0
https://www.dropbox.com/s/22fq73l4iew0tvz/IMG_0481.JPG?dl=0
AudioQue AQ1200
Specifications
Model AQ1200D
$100
