Flexing plexi?
stronger as in it will flex alot more before it will crack yes, mdf is more rigid, stiffer, plexi will flex a ton before it will break or crack, flex way longer than mdf. , For a peice that big I would do lexan
Lexan is a brand name of plexiglass.
The thickest I see for lexan is 1/2".
Can you not split it any way to maybe brace it? What is 37" wide?
Back of an enclosure,Yea,I might redesign it and some how split it in half to be safe.
He means..
''Polycarbonate, aka lexan, is a tough and durable plastic material which is hundreds of times stronger than glass and many times stronger than acrylic. Polycarbonate will meet those demanding applications where glass and acrylic fall short.''
don't necessarily have to SPLIT the glass.. I assume you are doing two 3/4 layers of mdf on the back to flush the mdf.. well on the first piece of wood do a trim the entire way around for the plexi to screw to and do a middle piece about 3" wide to help keep from flexing.. then put a beauty panel on over it and you will be good..
He means..
Your thread was talking about plexiglass, then Lexan was brought up like it was something different and better. Lexan IS plexiglass, it's just a brand name. If your thread was asking about acrylic, then yes, Lexan(plexiglass) would be stronger.
Your reply is confusing, you seem to say its the same, AND different. Only one answer is correct. Lexan is a polycarbonate. Plexiglass is an acrylic. They are not the same thing.
CJL
CJL
oZone
audioholic
