have a gallon of accetone handy for cleaning. if you get some resin on you, the accetone will help get it of very easily, altho its not suggested to make contact with the skin. but a little wont kill. wear a long sleeve shirt to avoid using the accetone. you can clean anything with the accetone before the resin dryes, thats including your bruch or roller so you can reuse them.
wear a mask designed for fiberglass fumes, etc. you dont want to inhale none of that crap, very bad for the lungs.
when mixing your resin till you get used to how the resin reacts to the hardner, mix in 8oz batches. you can use plastic cups. they are cheap and you wont have to clean them to reuse them.
cut your fiberglass mat or cloth to 4 x 10 piece or smaller depending on the job, it make laying it down allot easier.
if youre using a brush poke, not brush, that will get the bubbles out. and wont pull the hairs out of the mat.
dont wear any cloth that you may want to wear later. so use the ragiest shit you have. wear snikers not sandles, if you wear sandles wear socks.
dont over wet out the fiberglass. you want to use the least amount of resin and the most fiberglass. thats where the strength is going to come in to play. but make sure that there are no dry patches of fiberglass.
make sure you stir, shake, mix the resin inside the can well before poring it into a smaller container or one batch will cure faster then the other.
tape anything you dont want resin on.
you can get free mixing sticks at home depot paint department. lol
if you have any high spots on the area youre working on. make sure you knok it back down by sanding before you lay your next layer down, or youll have some air bubles no mater what.
