- Thread Starter
- #31
yes the wood is mdf. I use bondo to fill in imperfection and use primer. wet sand 400 grit . Then lay down the base color paint. Make sure there are no winds at all. After that sand down with 800 grit. Lay down the clear. let it dry, sand with 1000 grit. Clear again then sand down with 1500 grit. Polish it with a buffer. Soounds easier than doing. Basically paint it as if you were painting a car.
