well since my dam transmission went out today in my van , and no one is realy interrested in my fs section im left with no choice but to play with the actual system in my van...i need my van fixed so i can do my job ....
so here goes.
its 4 weeks old never droped voltage, ran at 1.33 ohms gains set with a dimm , has double fans blowing on it to ensure it stays cool
mounted in the back of my van in the dark so its still 10/10 cos. and 10/10 working i still have orignal box, remote/wire. instructions ect that orignaly came with it....i didnt buy it off of ebay because of geting screwd over 2 times in a row on ebay i bought it from a local shop and paid $435 for the amp
im looking to get $325 out of it?......
Hi Speed Digital Circuitry
• Fully Regulated PWM Power Supply
• Four Way Protection Circuit
• 1 Ohm Stable
• Bridging Synchronization
• Variable Low Pass 50Hz-150Hz
• Variable Subsonic Filter 15Hz-40hz
• Variable Subwoofer EQ @ 45Hz
• Phase Switch 0-180
• Remote Dash Mount Low Level Gain Control With Cable
• Frequency Response: 15Hz to 150hz
• S/N Ratio: 100 db
• THD: 0.5%
• System Distress Indicator
• Inputs Sensitivity: 200mv-8v
• Dual Mono Speaker Output Connectors
• Platinum Plated Heavy Duty Power & Speaker Terminals
3200 rms @1
2500 rms @2
1700 rms @4
its fused with 150 amps of fuseing and manual says that it uses upwards of 190 amps at max current draw
anyone interrested that doesnt want to lowball ?
i dont have a picture of the amp in the van, im not at home van, ill get pics of the amps condition/location tommrow when i get home
so here goes.
• 1 Ohm Stable
• S/N Ratio: 100 db
• THD: 0.5%
3200 rms @1
2500 rms @2
1700 rms @4
