Sold F/T Modded MTX 1501d
saosin
I'm looking for an amp that pushes 1500+ at 1 ohm need a SSF on it, if anyone has an amp that pushes 2000+ at 1 ohm i will throw in a pair of memphis m3 subs they are 12" dual 4 ohm, pm me or e-mail me at daviddim@gmail.com or daviddimailig@cingular.com
This amp is like Scottie J's amp, modded to take higher voltage and to take a 1ohm load depending on your electrical system it will push 1800+ watts at 1 ohm, i would use this amp for my xxx but i need an amp with an sub sonic filter
thanx
That's just plain stupid. You DO NOT need a SSF...period. When i had my jbl600.1 on a ported setup, I bought 20hz SSF FMODs (RCA in-line SSF...plug them in before the RCA's to your amp) from parts express. But then, I decided not to use them b/c in all honesty they are not needed. As long as you are responsible with your sub, and you don't CLIP THE HELL out of your amp WELL BELOW tuning ON PURPOSE...then it's not needed. I haven't used an SSF in over two years on any of my setups (eD 12k's (e-logo), 1 eD 8z, 2 12" SI magnum d2's, 1 18 XXX...). So, don't waste your time or money...keep the amp!
NG
NG
Ahem! You're wasting time and money...seriously...
NG
NG
I agree //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif mainly becuase the slope on most ssf's arent sharp enough and they end up cutting into the bass we want! Anyway... to each his own...
bump for a good amp //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
bump for a good guy and a good amp...I might want it back. Let me see what happens with another amp I'm looking at first. but if not...then bump...
I think unless I get it //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif you should keep the amp. Really you don't need the SSF in most cases if you watch what you do.
ok sales is off i'm not selling it after hitting my head a couple times on a desk realzing how much i paid for it and it was cheap i can't beat it.........
D@MN...i wish i would of seen this earlier!
i would of traded mine...//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
saosin
saosin
Chicago, IL
jellyfish420
