Sold F/S Rockford Fosgate CRAZY GOOD DEAL
splmegavan
i am selling my rockford T1000bd this amp is very underrated, it will put out 1596 watts at 1 ohm i have the birthsheet to prove it. im asking only 225.00 shipped for the amp. i have the original box, birthsheet, bass knob, and bd sync cable to strap 2 of them together if you want. this amp does not draw alot of voltage so it will work with most eleectrical systems, it has a built in 150 anl fuse and has built in fans. it in great shape as you see, its got lil dust on it an some minor scratches it cleans up nicely, i run it as an everyday amp and the thing slamsmy 4 kicker 15s if interested message me
Details:
**1000 Watt RMS Class BD Amplifier RMS Power Ratings: **500 watts RMS x 1 at 4 ohms **750 watts RMS x 1 at 2 ohms **1,000 watts RMS x 1 at 1 ohm **Para-Punch bass EQ (0-18 dB with variable center frequency between 35-70 Hz) with wired remote control **MEHSA- High Performance Thermal management design for bigger power with more consistent thermal stabiity **MOSFET power supplies and outputs **TOPAZ - Circuit for eliminating engine noise **NOMAD - Advanced short circuti and power protection **MasterSync - allows one amplifier to manipulate another amplifier's gain, EQ, **Infrasonic and crossover controls **PowerSync - Allows bd series amplifiers to be "strapped" together to create one massive power combination **variable low-pass filter (32-250 Hz, 24 dB/octave) **Infrasonic filter: 12dB/oct Butterworth alignment protects the amp from unwanted ulta-low frequency information, increasing the usable power output and reliability **RCA Preamp Outputs **Phase switch: 0 - 180 degrees **Cast aluminium heatsinks - allows more power into a smaller heatsink be allowing engineers to localize heat in specific areas **3-Stage Variable forced convection - heatsink design that keeps the amp's internal comonents cool **1/0 AWG power and ground connections with internal ANL fusing **Dimensions: 18" L x 12.8" W x 2.66" H **CEA-2006 Compliant **Amplifier Class BD **Number of Channels 1 - Mono **RMS Power (4 ohms) 500 watts x 1 channel **RMS Power (2 ohms) 750 watts x 1 channel **RMS Power (1 ohm) 1000 watts x 1 channel **Bridged RMS Power N/A **Peak Power Output N/A **Minimum Impedance Unbridged 1 ohm **Minimum Impedance Bridged Not Bridgeable ohms **THD at Rated RMS Power N/A **Speaker Level Inputs No **Preamp Outputs Yes - 1 pair **Built-in Crossover Low-pass (LP) **High-Pass Crossover Frequency N/A **Low-Pass Crossover Frequency 32 - 250 Hz **Subsonic Filter 28 Hz **Signal-to-Noise Ratio N/A **Channel Separation N/A **Bass Boost 0 - 18 dB **Bass/Gain Remote Yes **Fan Cooled Yes **Fuse Rating 150A x 1
[/img]
[/img]
its crazy, because its been said many times, but make deals at your own risk on here...obviously, anyone can scam, but in all my transactions i have made, i have made sure that they all have at least 5 transactions on this site, no bad feedback and proof of product. i have been lucky so far, have had all good sellers..
splmegavan
splmegavan
dayville
matrxx dude
