Sold F/S - Rainow CMX Kicks - Tang Band 6.5 Subs.. Kicker 30 Band EQ
Etac
Angry Bunny Killer
All Prices Are Shipped.
CMX Kicks Set (2 mids, 2 tweeters, 2 crossovers) - $220
First Up is a set of CMX Kicks.. I will part them out for prices below... there are a couple of minor issues you should be aware about however. I blew one mid awhile ago, and just got a new one back from warranty... the only power the new mid has seen is to make sure it works, but since it was rebuilt straight from the factory, it lacks the rubber magnet cover and some stamping on the back.. also the angled mounts for the tweeters small clips broke that hold the tweeter in place, without the screw.. with the screw.. or some other type of method to hold it in place (i used electrical tape and you couldnt even tell) this shouldnt make a difference. otherwise in costmetic (no dents or scratches) and mechanical (coils read fine) they are in basically perfect condition.
Cal 25 Ti Tweets - $105 w/ crossovers
CMX Kicks Mids - $130
Tang Band 6.5 Subwoofers - $80 (for pair)
Perfect Condition
DIAPHRAGM MTL Paper
SURROUND MTL Rubber
NOMINAL IMPEDANCE 4 Ω
DCR IMPEDANCE 3.6 Ω
SENSITIVITY 1W/1m 83 dB
FREQUENCY RESPONSE 38-800 Hz
FREE AIR RESONANCE 38 Hz
VOICE COIL DIAMETER 38.5 mm
AIR GAP HEIGHT 4 mm
NOMINAL POWER 70 W
MUSIC POWER 140 W
FORCE FACTOR, BL 8.67 TM
MAGNET WEIGHT (oz) Neodymium
MOVING MASS 34.91 g
FERROFLUID ENHANCED No
SUSPENSION COMPLIANCE 423.31MN-1
EFFECTIVE PISTON AREA 0.0140m2
Levc 0.34mH
Zo 33ohm
X-max 13 mm
Vas 11.78 Litr.
Qts 0.40
Kicker 30 Band Equalizer- $105
Perfect Condition
im removing the cal 25 ti's, there a problem with one of the tweets, i was testing them to make sure incase i sold them and for some reason one plays alot louder than the other, yet the coils read basically the same /shrug
pg 7 ttt
ahh this post was supposed to die lol
somethings wrong with one of the tweets so i took em off from being for sale (in my other post)
and the mids were sold. sorry
Etac
Angry Bunny Killer
Etac
Jersey
1blualti
