Sold F/S: Precision Power PC4800.2 4-Channel
rtillaree
F***, Strong
this is a VERY solid amp, I believe this was one of the last models made in the US, if I’m not mistaken… this thing has got some serious power, I hooked it up and set the gains the best that I could and I ended up blowing one of my pro 50’s…but it did push my sl80’s and my z6’s very nicely, about one of the cleanest sounds I’ve personally had…
The only issue that I noticed is that once the deck is powered up, at zero volume, there is static coming from all 4 channels, this was present until the volume was set to a mid or higher level, and it is only present once the system is powered up…after messing with the gains, I noticed that when they were way down it didn’t have this static noise in the line, so I’m guessing that there maybe something wrong with the gain…
Aside from that and some cosmetic damage I believe this amp is in fit condition, and it has never been opened or serviced which is present in the image posted below…
ALSO: i DO have the 2 speaker plugs in my car, i just didn't feel like getting them out for the pics...
Specs per AmpGuts:
4 x 100W @ 4 ohms
4 x 200W @ 2 ohms
2 x 400W @ 4 ohms bridged
THD: 0.02% (4 ohms)
Freq. Response: 4.5Hz ∼ 100kHz (±0.5dB)
S/N Ratio: 110dB
Damping Factor: >500
Max. Current Draw: 100A
Fuse: External 80A
Dimensions: 23.75" x 8.98" x 2.24" (60.3cm × 22.8cm × 5.7cm)
Manufactured in 2000
$275 + shipping
not really looking at any trades right now, but will still listen...
how about you keep this amp and buy my pcx-1250, then you'll have a somewhat matching set. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif vice-versa won't work
bump for a nice 4-channel.
this amp is too much for my application man...the thing is beast like...dont get me wrong, i love it...and its one of the last great products...but i would just like to get some $$$ to buy some batteries and finish my install...
rtillaree
F***, Strong
rtillaree
Orlando
rtillaree
