Sold F/S pre DEI PPI PCX4125 SQ amp 4ch cheap
Louisiana_CRX
dem shoes......
This is an awesome pre DEI PPI PCX 4125 ...this is one of the last good PPI amps it is under rate at 125x4 at 12v's...It has never been mounted but I did hook it up in the car for a week or two to test it and make sure everything worked properly....This is a great deal on a basically brand new PPI PCX 4125 $325 shipped CONUS
These are awesome specs on an Active AMP this is some very awesome SQ for $325 shipped CONUS //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif The power is very under rated at 12v's
# Product MPN MPN: PCX-4125
# PCX-4125 4-Channel Amplifier
# 125 watts x 4 @ 4 ohm
# 250 watts x 4 @ 2 ohm
# 500 watts x 2 Bridged
# Frequency Response: 4.5 - 100k
# S/N Ratio: 115 dB
# THD: 0.02%
# Q-Bass Plus
# Cooling Fan
# TC-X crossovers
# Key Features
* Amplifier Type: Multi Channels
* Bridgable: Bridgable RMS Power at 4 Ohms: 125 W x 4 RMS Power at 2 Ohms: 250 W x
* 4 Performance Frequency Response: 4.5 Hz - 100000 Hz
* Signal to Noise Ratio: 115 dB THD at Rated RMS Power: 0.02 %
* Crossover / Equalizer Bass Boost: With Bass Boost Other Features
* Input Voltage: 12 volt
* MOSFET Circuitry:
* Dimensions Width: 10 in. Depth: 25 in. Height: 2.38 in.
* More Information Details: Expanded system flexibility begins here with the PCX Mono and Multi channel amplifiers. Whether you need a mono, four channel or five channel amp, PCX amplifiers give you limitless system configuration potential. At the heart of all of the PCX amplifiers, is the TC-X crossover. The TC-X crossover allows complete control of the frequencies from 30-4KHz, HP/LP/Full. On the multi-channel amplifiers, you have the front channel crossover acting as a 2-way, tracking crossover. What this means during installation is, by sending the crossover front channel signal to the rear channel, you now have the ability to Bandpass the rear channel. Every limitation has been eliminated from the PCX Line of amplifiers... What else would you expect from PrecisionPower.
Louisiana_CRX
dem shoes......
Louisiana_CRX
Piney Hills of Louisiana
throatrattling
