f/s PPI BK800.4
RoYALbLUE08
ppi bk800.4
p.s, i do have a box for it, but im in a different city for the summer and the box is in my house, so either you want the box and i guess i can ship it to you later or you dont want/need the box
and also the endcaps are in my house as well, so i will ship those when to buyer when i get back to my other house
Very good condition. and pretty scuff free. the only thing is that the screw terminal for the ground got stripped alittle so that might need a replacement but it still can definately turn with a drill. thats the only flaw it has because my drill bit was messed up when i was trying to screw it in. other than that its in excellent condition
-Forgot to mention those are pieces of velcro on the top that i mounted my audiocontrol lc2i, i will take it off and clean everything for buyer
155shipped (cost around 20 bucks to ship)
4-Channel Class A/B Black Ice Series Car Amplifier
RMS Power Rating:
4 ohms: 130 watts x 4 chan.
2 ohms: 200 watts x 4 chan.
Bridged, 4 ohms: 400 watts x 2 chan.
Black Acrylic Surface
PWM MOSFET power supply
Variable Bass Boost (0, 6, 12 dB at 55 Hz)
SMT(Surface mount technology) Circuity
Variable 12dB high, low, & subsonic filters
Band-pass crossovers
Balanced signal input
Turn on/off delay
Tri Mode capable
Heavy duty aluminum alloy heatsink efficient heat dissipation
Nickel-plated RCA level inputs
Nickel-plated screw terminals
Damping factor: >200
Variable 180° phase control
Total harmonic distortion: 0.5%
Input sensitivity: 0.2V-5V
Dimensions: 17"L x 8-1/4"W x 2"H
4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier
1-year Manufacturer's warranty
They look simple...high pass...lowpass or bandpass...nice...can go active off this...is it clean sounding?
yeah i had it running my HAT speakers. im no audiophile yet i dont know what to tell in determining sound quality like you guys here lol but it did pretty **** good to me. i just want to go a differnt route and try the PPI 900.4
for the HPF i dont know which HZ im on cuz it goes from 15-4khz, same with the LPF, the range is so wide on the dial idk which frequency im on,
im guessing this is meant to run active? im not good with this kind of stuff yet so id rather get an amp with a regular like 50-500hz dial or something like that
RoYALbLUE08
RoYALbLUE08
NYC
RoYALbLUE08
