Sold F/S Power Acoustik LT720/4 Multi-Channel $50 shipped
Naxis2k1
grade A whiteboy
in closet collecting dust maybe someone could use it.
Power (stereo): 85 W RMS x 4 @ 4 ohm, 4 X 100 RMS 2 Ohm
Briged Power 2 X 200 RMS 4 Ohm Bridged, 720 Peak Bridged
PWM Circuitry
Tri Mode Capable
THD at Rated Power: 0.02% @ 4 ohm
S/N Ratio*: >98 at rated power
Frequency Response: 10 Hz-30 KHz
Variable Low Pass 30-500 Hz
Variable High Pass 50-500 Hz
Variable Subsonic Filter 60-200Hz
4 Guage Power/Ground Connections
RCA Line Output
Diamond Cut Heat Sink
24 dB boost at 40 Hz
Dimensions: 11.25"L x 11"W x 2.25"H
few marks here and there perfect working order tho. will ship in orginal box.
If you still have this friday will you take $40 shipped. I'll send half on friday the other when I get the amp. Any references? No disrespect but dont trust people I dont know.
Naxis2k1
grade A whiteboy
Naxis2k1
Phoenix
Naxis2k1
