Up for sale is:
USED -- MTX 1501d Mono Amplifier -- $300
There is a few visible marks but they do not effect performance and a couple of the rubber feet are loose , not falling off loose but loose.
This amplifier is the one with the most teeth. It's got it all. Adaptive Class D Technology, for high power in a small package. Anyone can make a high power amplifier in a big package. But it takes smarts and careful engineering to produce big power in a small footprint. Adaptive Class D Technology is how we make this amplifier so efficient at producing power. The crossover is low pass, variable from 40Hz to 200Hz. And, we've even built in our compression circuit, to protect your woofers at high SPL levels. Add in the EBC2 and the Thunder EQ and this is one amp to be feared.
Thunder1501D
Class D Amplifier
Input
Low Level Input
Crossover(s)
Low Pass @ 40Hz-200Hz - Variable
Compression Circuitry
Thunder EQ
EBC2 Port
RCA Output
Low Pass Only
Dimensions (with ISO Feet)
17.8" x 9.75" x 2.1"
45.3cm x 24.8cm x 5.3cm
RMS Power 12.5 VDC
2 Ohm Load
1000 w x 1
4 Ohm Load
500 w x 1
Dynamic Power 14.4 VDC
2 Ohm Load
1500 w x 1
4 Ohm Load
750 w x 1
And a pair of
USED -- IDQ 12" Dual 4 Ohm V.1 (black logo ID logo) -- $40 each or $75 for both
Cant find any stats for this version. Im sure theyre close to the v.2 in t/s parameters and it is rated at 300wrms I believe.
The speakers scratch when they move (misaligned VC or something) and need to be reconed. Called Image Dynamics and they quoted me $75+ shipping there , they pay shiping back.
I have no referances because ive never sold anything online , so I wanted to do this PICK UP ONLY. Im in South Miami, Florida 33157. Send me your e-mail for pics.
Thunder1501D
Class D Amplifier
Input
Low Level Input
Crossover(s)
Thunder EQ
EBC2 Port
RCA Output
Low Pass Only
RMS Power 12.5 VDC
2 Ohm Load
1000 w x 1
4 Ohm Load
500 w x 1
2 Ohm Load
1500 w x 1
4 Ohm Load
750 w x 1
And a pair of
