hello everyone!
up for sale is a Kenwood Kac-7203 amplifier that was installed by me into a friends ford escape. the amp is practically new and maybe has seen about 20hrs worth of play time. it was pushing 2 Kenwood KFC-w3011.
initially there were 2 amps and were going to push one sub each but a problem occurred with one amp as we accidentally reversed the power source and fried it. so he ran the single amp on the 2 subs for the time being.
well the blown amp was returned and exchanged and well they sent him a 2008 model of similar type which is a KAC-7204. he is trying to have a matching system with matching amps and has decided to look for another kac-7204.
so with that said the kac-7203 is up.
the amp has minor scratches in the mounting screw holes from where you mount the amp. also there are minor scratches on the area where the speaker terminal post are.
everything else is in pretty much perfect shape. amp will come in original packaging along with all items that came with amp including manual.
Specs:
2-Channel Power Amplifier
RMS Power Rating:
170 Watts x 2 Channels @ 4 Ohms
250 Watts x 2 Channels @ 2 Ohms
500 watts x 1 Channel @ 4 Ohms (Bridged)
High-Pass Filter: 50 - 200 Hz, 12 dB/Octave
Low-Pass Filter: 50 - 200 Hz, 24 dB/Octave
Variable Bass Boost: 0 - 18 dB @ 40 Hz
MOSFET Switching Power Supply
Cooling fan
CEA-2006 Compliant
High- and Low- Level Inputs
RCA Preamp Outputs: 1 Pair
Tri-Way Capable (Crossover Required)
Frequency Response: 20 Hz - 20 khz
Dimensions: 11-1/4" L x 14-15/16" W x 2-9/16" H
cosmetically 9/10
performance 10/10
pics!
looking to get $75 + Shipping
i have few refs here. sold only 3 items on here but have made a few purchases and a trade. buy with confidence. Paypal only!
Specs:
RMS Power Rating:
Cooling fan
CEA-2006 Compliant
cosmetically 9/10
performance 10/10
pics!
