Sold F/S KAC-8401 Kenwood 60W RMSx4 4/3/2 channel Amp
03Black350Z
This amp is in working condition. This unit has a good cosmetic appearance as well. It was in my car until about a week ago. Im selling my amp because I am going with a different channel setup. The amp was bought in Jan 2004. I used the amp in both 3 and 4 channel mode with no problems. No DOA or full refund. I have not sold on this forum before but my ebay name is omar2006.
Features
* MOSFET Power Supply
* Torroidal Noise Suppression Filter
* Copper EE Core Power Transformer
* Dual Secondary Capacitors
* Ground Isolation Input Circuit
* Cast Aluminum Sandblast Finish Heatsink
* Dual Variable (50-200 Hz) 12 dB / Octave Low-Pass Crossovers
* Dual Variable (50-200 Hz) 12 dB / Octave High-Pass Crossovers
* Switchable 6 dB Bass Boost at 90 Hz
* Gold-Plated Preamp Inputs & Outputs
* 2 or 4-Channel Input Selector
* High and Low Level Inputs
* 2 Ohms Stereo / 4 Ohms Mono Stable
* Blue Triangle Power Indicator
* Gold-Plated Screw-Type Power and Speaker Terminals
Multi-Channel Amp Specifications
* Amplifier Type: Multi-Channel
* RMS Power @ 4 Ohms: 60W x 4 @ 14.4V
* THD at 4-Ohm RMS Power: 0.08 %
* Bridged RMS Power @ 4 Ohms: 180W x 2 @ 14.4V
* Speaker Level Inputs: Yes
* Preamp Outputs: Yes
* Built-In Crossovers: HP/LP
* Bass Boost: 0 or 6 dB
* Frequency Response: 10-30,000 Hz
* Signal to Noise Ratio: 100 dB
* Fuse Rating: 40 amps
//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif asking $75 shipped. paypal preferred //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
03Black350Z
03Black350Z
Kansas City
03Black350Z
